HP Officejet J5780 All-In-One InkJet Printer Logo
Posted on Dec 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I do not know to copy on both sides of the paper, can you help?
Anonymous
Level 3:
Genius:
  • Master 1,605 Answers
  • Posted on Dec 16, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1605
Questions
Helped
746510
Points
3939
I don't think the HP Officejet 5780 have the capacity automatic for double side copy.
nothing in the printer specification have the double side copy listed.
what you can do is copy one side and trun the paper over and copy the other side.
1helpful
How do I copy 2 sided copy from 2 sided original on hp Officejet 4630 e- All-in-One Series
copy one side, then take copy and put back into blank paper try and then copy other side. trial and error will tell you how to put paper in paper tray but usually printed side up, top in
2answers
Constantly jammed paper when print or copy multiple pages
check if the paper size not match with that sitting in printer sitting and the aplication you use
Canon IR1600 Copier
what do you mean copy halfway only on the top of the paper or only on down side of the paper, or only on the left side or right side of the paper...are u using A4 paper..?
2answers
I was wondering if there is anyway that you can make double sided copies and if so how??
Only copiers fitted with a duplexing unit will automatically make a double sided copy. I assume yours does not have this accessory.
You can always make two sided copies manually. You need to first work out the paper path, so mark one piece of paper with an arrow showing the top and the direction the sheet was placed on top of the paper feed tray. Make a copy and you will now know whether the top or bottom of the paper as loaded gets printed on. Now place that sheet back in the paper feed tray again with the arrow face down in the paper tray, but still pointing in the same direction as before. Print side two and you will now have a double sided copy. If the reverse of the copy is facing the wrong way then you know that the paper needs to go into teh paper tray with the arrow facing you. Hope this makes sense, but it just needs a couple of trial runs to get to understand which was round to put the paper back in for the revers side to be printed. Always keep the final successful double sided copy, marked up for future reference, as it is so easy to forget which way to put the paper back in several weeks later.
Is it possible to do two sided copies with this printer? If so, how can i do that?
as far as i know this can not make a two sided print automatically, but i think you can make a two sided copy manually. first copy the first side then return or place the paper on the by pass tray then print the second second side. hope this help
1helpful
I get a paper jam every time I try to manually make a copy on the second side of a copy. First side no jam. Help. Derek
hai,
Open the leftside lower cover (below the dlivery door).
i think duplex revesing area have old copied papers. if have remove it, then
Check the paper passing rollers dirt or demage, clean it, hold properly
then clean the sensor of paper reversed area.
best of luck
Do not know how to print two-sided documents in landscape mode.
This one is easy but it will take trial and error before it will work. You need to copy one side then take the same copy and put it back in drawer. Trial and error come from you making the 2nd side to see what side and direction to put paper back into the paper tray to get it correct. Hope I did not confuse you. Let me know if this helped or fixed your issue.
How to use
Does the copier have a duplexer? Automatic 2-sided copying (duplexing) was an optional feature for the EP2030. If there is a drawer in the lower section of the copier labeled "duplex" then your unit has this feature.
To use it, simply select 1>2 (for single-sided originals) or 2>2 (for 2-sided originals) on the "Orig>Copy" section of the control panel (toward the left side).
If your copier is not equipped with a duplexer, the only way you can make 2-sided copies is to copy the first side and then load the copies back into the paper tray or the manual bypass on the right side of the unit.
Note the the copier copies on the bottom side of paper fed from the paper trays, and the top side of paper fed from the manual bypass.
You can download a .pdf file of an operator's manual for this copier from the Konica Minolta website.
Copy Orientation
Is it cutting off on all of the paper trays on the same side of the page? Lead edge or Trail or front to back side of the copier? You can adjust the front to back in the paper tray and the lead and trail are adjusted in service mode. Do the amout of the cutting off change at all? You may have a reg. clutch problem. Also you can adjust the X & Y amouts in service mode as well.... It could just be as easy as making sure the paper tray guide's are tight against the paper in the trays...
k24674
Grand Canyon Tech
Grand Canyon Tech
