Any more products needed to install this in the truck
Oh yes. You will need an interface for the remote starter to work. You can purchase an FLCAN or an XK09 but, these components must be programmed to function properly. You can purchase an EVO-ALL; it does not need to be programmed. The installation instructions can be downloaded at ifar.ca. The three components mentioned above will work almost necessary components in the vehicle . Hardwire the system with 5303 and then wire the interface to the vehicle through the CAN data wires.
SOURCE: i bought a 96 dodge
Hi!!
Click on the following link to get an owner's guide for the Avital 2200, http://www.avital.com/Support/OwnersGuide.aspx
If you can't find what you're looking for on the manual, click on the site and register to obtain more information http://www.avital.com/Support/.
Good Luck!! A 4 THUMBS UP rating for this solution would be greatly appreciated. Thank you for using FixYa!!
There are two types of starters for Dodge, if you installed new battery, check to see if the remote start is to ignition module or starter solenoid, then make sure the circuit has not been closed-they go in series circuit!
