SOURCE: Dell Monitor 2001FP Blank Screen
I have to ask....... Do you have it on the D-Sub position (if running VGA) or the DVI-D position (Running HD mode)? If it's in the wrong input position (there are 4 available),then the monitor will look like it's working but the screen will be blank (act exactly as you describe). If you have it on the right input and still have a blank screen, then I have to agree with Pulliam.
SOURCE: Dell LCD Monor light keeps blinking green, screen
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: 2001fp the screen is black the power light is
The problem can be in the inverter board: http://www.lcdrepair.us/2001FP-INVERTER.html
You can try replacing the inverter and hope that the problem is not in the backlight assemblies. You need the test lamps to verify the function of the inverter board. Do you get steady 20vdc feeding the inverter. You can also try heating up the two black electrolytic caps on the inverter board to see if the inverter will fire up using hair dryer, when bad caps with high ESR are heat up the ESR will go down.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
SOURCE: Dell UltraSharp 2001FP (Gray) 20.1" LCD Monitor
Most likely, this is failing "inverter."
The backlight of the monitor (that makes the image visible) is controller by a special chunk of electronics called an inverter. They tend to fail over time. The symptom is that the backlight either never comes on, flickers, or shuts off after a short period of time.
It is a moderately advanced repair job to change out the inverter, but you can usually get the part on eBay. Search for the exact monitor model number and "inverter".
The 2001FP has six lamps and the inverter is fairly expensive. You might be better off putting that money towards a newer monitor.
