Before i put disk wxp disk in it says no bootable CD in ATAPI CD-ROM pex-e61 media test failure check cable and pxe-mof exiting Intel boot agent when i put windows xp pro service pk 3 in it says cannot find and hard disk.
SOURCE: Evo N200
The BIOS, which handles the initial start up of your computer, cannot find your hard drive and thus cannot boot your operating system (ie, Windows). Open up your computer and confirm the power cable is firmly connected to the hard drive and that the cable that connects the hard drive to the motherboard is firmly secure. If both of these check out, then try downloading this bootable CD on another computer. This CD, among other things, has a few hard drive utilities that will help further diagnose the problem. http://www.ultimatebootcd.com/ Finally, if the utilities on this CD are unable to see the hard drive itself, then is may need to be replaced. Try testing with another hard drive or another cable to connect it to the motherboard.
SOURCE: Trying to start my computer
http://www.hitachigst.com/hdd/support/download.htm has a Disc Fitness Test programme. It produces a floppy to boot from DOS into Windows. My Satellite 1110 has the same error message, PXE-E61. The BIOS shows "no HDD". The DTF found no fault on the HDD. (full test took 45minutes) Give it a try. I know, you need a working computer to down load it-- and DOS and a floppy drive on the faulty one. There are USB adaptors for floppy drives. Tomorrow I prise the 1110 apart and will clean all the cable and connectors. Good luck. Bryan
SOURCE: PXE-E61 : Media test failure
It sounds like your hard disk has gone, or not being recognized by the computer... Check if it seats well in it's place.
Unfortunately, laptop HDDs don't last long these days.
SOURCE: no bootable CD in ATAPI
try downloading from here
http://pci-ven.com/driverdetector/realtek/rtl8139realtek/realtek-rtl8139-x-8130-810x-pci-fast-ethernet-controller-v2-17-051202-.html
good luck
First of all when i turn my Toshiba TECRA on it says No Bootable cd In ATAPI CD-ROM Intel(R) Boot Agent FE v4.1,09 Copyright (C)1997-2002, Intel Corporation Intel Base-Code, PXE-2.1 (build 083)
Copyright(C)1997-2002, Intel Corp PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent.
Press any key when ready i press any key it says same stuff also i put windows xp pro with service pack 3 32bit cd and the it reads and starts coping windows then it says no hard drive
The hard drive is not been detected due to hardware failure.
