GE WBSE2090A Top Load Washer Logo
Posted on Jul 09, 2012
Washer fills spins but wont agitate - GE WBSE2090A Top Load Washer
Dean
Level 1:
Habit-Forming:
New Friend:
  • Contributor 4 Answers
  • Posted on Sep 30, 2012
Dean
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
Questions
Helped
2018
Points
11
5 Related Answers
Anonymous
  • 291 Answers
  • Posted on Sep 03, 2007
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
A
Anonymous
  • Posted on Feb 17, 2008
SOURCE: will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Anonymous
  • 3361 Answers
  • Posted on Apr 01, 2009
SOURCE: GE Washer agitates when I try to fill it up with water,wont fill
You have a bad water level switch or a clogged plastic hose that goes to the water level switch.
Use a putty knife to open the front panel. The clips are at the top right and left sides just below the top lid. Push in on the clips and pull out on the panel.
On the left side of the tub you will see the air dome with aplastic hose connected.
Remove the hose and insert a small wire into the air dome hole to clean it out ouf soap scum. Then, blow through the hose and listen for a faint click in the water level switch. Also check the hose for a hole or being pinched.
The set the timer for spin and run a spin cycle then retry the water level and wash cycle.
mgprice
Mike Price
  • 744 Answers
  • Posted on Jul 19, 2009
SOURCE: GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
jimorris77
  • 411 Answers
  • Posted on Dec 02, 2009
SOURCE: GE washer model WJRR4170E1WW won't spin or agitate
.I am not a repair professional. I am a 78 year old man
who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
1helpful
2answers
Wont agitate or spin everything else working
hi Paulmahoney.
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
read up some more at this link might help you out some more.
Washer Doesnt Agitate or Spin
or this link.
washing machine Wont agitate or spin Google Search
My washing machine will'nt wash and little water come out to fill it
Washing Machine Will Not Agitate or Spin - Home Repair ...
? 15:00
www.youtube.com/watch?v=wUSmUSWWIS4
Oct 20, 2013 - Uploaded by Robert DIY This washing machine would not agitate or spin. There is a ...My washer also is not agitating or spinning but water will drain after a long while.
Troubleshooting Why the Washer Won't Agitate ' PartSelect ...
? 3:10
www.youtube.com/watch?v=LfWRyt1vj2w
Nov 5, 2012 - Uploaded by PartSelect
The only wash cycle that works is delicate none of the other washcycles work .... The washer still fills, drains and spins to dry butwill not agitate. ... Hi My machine wont spin or agitate on heavy loads like a few towels etc (fine
Washer wont drain spin or fill. but agitator works
with this many issues it sounds like the timer has a dead spot in it,especially your saying it wont even fill,then wont drain or spin,but only agitate
1helpful
Replaced the belt and still not agitating, switch seems good
If the machine fills, won't agitate, wont drain or spin, then you need to replace the lid switch.
if machines fills, wont agitate, will drain but not spin, then you need to replace the motor coupling
4helpful
Why wont my washer agitate
must be worn out dogs
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Washer wont agitate
if it wont agitate,then it's either your motor coupling,transmission,or capacitor
1helpful
Maytag washer wont agitate
Well if it does it in all cycles you can rule out the timer. I would say the agitator is maybe striped out.
2answers
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
