Samsung SCH-a650 Logo
Facory reset for character samsaung - Samsung SCH-a650
Have a polaroid tab7xc that the touch isnt working have tried to reset with button and still nothing any one help
try to hard reset the device
it would erase all data including your indvidual user data and all apps
back to facory as you got it from it the day you purchased
I need to reset my tv back to facory settings
To do a factory reset, you have to enter its service mode. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Samsaung z400 short mother board please help you
1helpful
After someone offered to take our photo with our Casio Exilim EX-Z600, all shots are lined and overexposed. How can we reset it?
I would recomend you to reset the camera, this will not affect any of your saved pictures. This can be done simpely by acessing : Menu, settings, reset to facory settings (Factory settings)
1helpful
My child of 6 years old added a pin number for dsi and then forgot it it is asking for an enguiry number 25178325 please help
YOU CAN FACTORY RESET YOUR DSI
POWERING ON THE DSI
THEN HOLD DOWN LEFT + RIGHT + START + SELECT ALL AT THE SAME TIME THIS WILL RESET TO FACORY SETTINGS....
1helpful
Facory reset for palm pixie
If you want to clear all data off your Palm Pixi and begin again with factory defaults, you can perform a hard reset on the smartphone.
1. Open Device Info.
2. Tap Reset Options.
3. Tap Full Erase two times.
18helpful
2answers
How do i reset my yamaha dx 100 back to original factory settings
yamaha dx100 reset. Press voice switches 1 and 2 while turning power switch on. Display will say test entry?. press the plus/yes button. This will reinitialize all memory to factory settings. Also the lithium ram backup battery voltage will be displayed as check level with a number representing the battery voltage. The number will be 10 times the actual battery voltage. A new battery will display 33 representing 3.3 volts. If your reading is below 22 then your battery is shot and will need replacing and if you turn the unit off it will probably get a scrambled memory again.
2helpful
PRO FAX SAMSAUNG SF 2800
jai un fax/tel samsung sf2800 je n'arrive pas a le regle en de tel façon qu'il sonne 3 fois puis il se converti automatiquement en fax,car c'est ecris en allemand.
salutation amicale.
Need to reset my toshiba 32mw7db back to facory settings
Try pressing mute on remote, then press mute again while holding down menu on tv to enter service mode. HTH
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
