SOURCE: Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
SOURCE: Amana Heat Pump Emergency Heat will not come on
On the heating element [behind the coil, (the springy thing)], at the top end of the element, there is a little thermistor I think it is called. You will have to remove the fan shroud. With the power off, check for continuity if you have a multimeter. If that is the problem (no continuity), you can pick one up at al local heating supply. Just have it soldered back in and reconnect. If the thermistor 's continuity is okay, remove the main board under the control knobs. I have seen these boards burn in the back where the relays are soldered on. If you're really good with a solder you can try to re-solder it. If not, it's about as cheap to buy a new unit as it is to buy the board. Good luck.
SOURCE: Blwoing cold air
Possibly, A thermal fuse located in the heater element circut could burn out. the CIrcut would show full voltage to the element but no heat out. Often there is also an auto reset high limit swich this could be out also opr instead of the fuse. THE FUSE IS ALWAYS LOCATED WHERE IT CAN "SEE" the elements. I E Inside the case where the elements are.
SOURCE: rheem criterion gas furnace
Check freon, you will need guages on the condensor, also make sure the cond, outside unit is operating
SOURCE: Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
