Heating & Cooling Logo
Posted on Jul 09, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why does my ac freeze up - Danby Heating & Cooling
Robert
Level 3:
Genius:
  • Danby Master 1,036 Answers
  • Posted on Jul 10, 2012
Robert
Danby Master
Level 3:
Genius:
Answers
1036
Questions
8
Helped
345524
Points
3136
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Anonymous
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 51 Answers
Anonymous
Expert
Level 2:
New Friend:
Greenhorn:
Answers
51
Questions
0
Helped
28074
Points
144
Quite true >air conditioners will freeze due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor.
Only one thing to add. Most evaporator (inside-cold air) fans are squirrel cage types. This type is adversely affected by dirt. A very small amount of dirt on the "cage" can cause a huge reduction in airflow leading to freeze up. In room air conditioners the evaporator fan is almost always hard to get to for cleaning.
Solution 1. Pull unit out, take outside and clean evaporator fan with coil cleaner or soap solution. Keep water out of thermostat compartment and away from blower motor. Rinse repeatedly until clean. Be careful not to damage any Styrofoam under the evaporator and around the squirrel cage.
Solution 2. Pull unit, take outside and remove evaporator fan. That's the squirrel cage right behind the coils that get cold. A little or a lot of dis-assembly may be required. You may need "long reach" allen wrenches and penetrating oil to get the squirrel cage hub set screw loose. If you have not done this before expect to spend a lot of time.
1helpful
2005 Mustang Convertible GT. AC blows cold air for a while then just slowly quits. I've had the refrigerant charged but it still happens.
Sounds like the ac system is freezing up, they are supposed to cycle the compressor on and off the keep the pressures in spec to prevent this but failed cycling switches and or overcharged or undercharged Freon can also cause this. When the ac quits pop the hood and look at the ac lines, is one of them covered in ice? If so it's definitely freezing up. Finding out why is the fun part.
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
Scotsman ice maker cme 506 makes ice and turns off and blinks refrigeration
First check to make sure condenser fan is running during freeze cycle. Now check to make sure condenser coil is clean. Her is all the specks on the machine.
1. Ice production ( 500 at 70/50
2. BTUs per hour ( 7000)
3. Maximum times in Minutes. ( 50 freeze, 14 harvest.
4. Refrigerant charge ( R-404A ) ( A-D series: AC 32oz, WC 20 oz. E series AC 23 oz, WC 14 oz, F series AC 23 oz, WC 13 oz
5. Suction pressure ( PSIG ) 35-37 - end of freeze, 120-125-Peak in harvest.
6. Discharge pressure ( PSIG ) 240-260- 5 min in freeze.
165-175- minimum in harvest.
7. Metering device.( TXV plus distributor, E series and higher have two TXVs. superheat 3 to 15 deg F.
8. Average comp.amps. 10-11 during freeze, 11-12 during harvest.
9. Batch Weight. 6.5-7 lb
10. cycle time, 23 minutes @ 90/70. 19 minutes @ 70/50
Armana APN14K-E portable AC freezes up
Lack of air flow or a lack of refrigerant are the two primary reasons why coils freeze. Clean the filter and the coil, if frost continues it is likely low on refrigerant.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
1helpful
The ac unit freezes up when it gets really hot and humid out and the ac blows hot air. what would cause this problem? it seems like the unit is freezing up and getting too hot and not allowing itself to...
This is caused by the low pressure AC compressor cycling switch, it is a very cheap part and located in the larger of the two AC lines coming from the AC compressor.
1helpful
AC freezes up after running two hours.
If it actually is freezing up,the low pressure switch is the likely cause.It is screwed into the large ac line near the firewall,witch is the cold line.If it is not there it is in the dryer,near the firewall,or under the air filter box.Follow the ac line(large ac line/hoses)from the ac compressor untill you come to the switch,that is the easy way to locate it.This low pressure switch causes the ac compressor to cycle on and odd according to the pressure sensed from the ac low side line.When it gets really cold the pressure is lowered,and there for it will cut off,and when the pressure rises,it cuts the ac compressor back on.It would be a really good idea to check the freon in the vehicle first.If the ac system is low on freon,it will freeze up on some vehicles.
Freezing up, home ac unit no air flow after running a while
A low freon level in the unit can cause them to freeze up. Are the fins behind the filter clean?
Ac freezing up
Most freezing is caused low refrigerant or temp control will not shut off unit if there is no humidity problem.
one or the other can be checked by an refrigeration tech.
2answers
AC not producing cool air
If this is a newer system there will be a freeze sensor. It may be low on refrigerant. I would check the obvious things first. Are the filters and coils free of debris? Finally only set the temperature to your comfortable temp not lower as this can cause freezing too (generally not below 70 degrees)
Top Danby Heating & Cooling Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
