SOURCE: Samsung SWA-4000 Wireless connection problem - Not connecting with main unit
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
SOURCE: problem with wireless conection between Samsung SWA-4000 and Samsung home theatre.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
SOURCE: SWA-4000 doesn't adquire signal of HT-TX500 Home Theather
I was having poor audio from the back speakers and didn't even know it; intermittently I'd hear them jump in volume, so myself being a little adventurous, decided to push the ID set button on the back, totally losing my ilnk... after digging and playing, I figured it out:
1.) Turn off the Head (main) Unit
2.) Power on the wireless receiver, being sure it is away from routers, other BT devices, etc.
3.) Push the "ID Set" button on the back of the wireless device and hold it until the lights on its front panel flash.
4.) Point the system's remote control at the Head Unit and punch in 0135. Its light should turn from red to blue.
5.) Perform step 3 again.
6.) Power on the head unit.
Should link up.
Might be some redundancy there, but it works :)
Also I found that after a few cycles It seemed to work better (perhaps cycled to a better channel?)
SOURCE: just connected the SWA-4000 wireless
Actually the SWA-4000 IS compatible with the htz-310t. I'm using the htz-310 system with an SWA-4000 and it works perfectly fine. under the list of compatible systems with the SWA-4000 you'll see the htz-310. so i don't know where the other answerer is getting his facts.
once you press the nubmers on the remote, 0, 1, 3 5 or whatever the numbers are. turn the system on with the on button on the system not of the remote.
if the blue led is on on the swa-4000 then it's communication, there's a link.
if you do a sound test it will not send the static to the rear speakers, at least it doesn't for me. however there IS sound ouf of those speakers. so i know they work.
SOURCE: Can a new tx card be used in a swa-4000
where can you get a tx card from, because i need one and yes it can as long it is for that specific wirless module ?
