GE 31GT660 TV Logo
Joy Trott Posted on Feb 26, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv is too dark
We have a Toshiba cz32v51, we can adjust the tv to be bright enough to see what we want to watch. Can you help us with this?
Simpson Neal
Level 2:
Novelist:
Champion:
  • Expert 236 Answers
  • Posted on Mar 03, 2007
Simpson Neal
Expert
Level 2:
Novelist:
Champion:
Answers
236
Questions
Helped
82440
Points
343
You didn't say how old your TV is. If it's very old the picture tube could be weak. IF not then there is a screen adjustment on the flyback transformer that you might try to adjust. Sometimes you can access this adjustment without removing the back cover. If you see an adjustment through a hole in the back of the cabinet marked "SCREEN" then you might try turning this control clockwise while watching the picture in a mirror. Only a slight adjustment may be needed. Don't make it too bright or the set may shut down or have small white (retrace) lines in the picture. If you have a projection TV then dust on the three picture tube lenses will darken the picture. These are general statements that apply to different TV's. I assumed that this is a direct view 32 in. TV. Stargazer
Screen is dark and almost unwatchable when watching dark sceens adjusting brightness does not help
Unplug the tv and take the particle board cover off the back of the tv. Abive the chassis, you will see a panel with 2 gold screws in in... it is an access to the tube lenses. Remove this panel and sneak your hand and a soft cloth up in there. Wipe the dust off the top of the lenses. See if this helps, best wishes.
3answers
DARK PICTURE
Just restart the tv and can u tell me company name and model no.........
THE PICTURE ON MY ZENETH PV6067DT TV WILL NOT GET
Make sure there is no light shining on the electric eye it will adjust brightness automatically also check bulb for dust and dirt
Nov 30, 2009 • GPS
Toshiba 35A44 Screen dark despite max brightness setting some OK
could be the sharpness, color, brightness, or a combination of them
1helpful
TV screen became a lot darker than normal.
Hi.
yeah, opened the front flap of the TV>menu> brightness> increase. Sorted. No problem.
ain't gonna bother asking any more questions on this forum..........no help at all .
cheers, Pat
Picture way too dark
Good day,
There is an adjustment on the rear portion of your units flyback. It controls the screen brightness. Check out on this.
chris
Darks too dark
try to open your tv and you can find the flyback ,in flyback you can see the screen and focus to adjust.use and try to rotate the screen,it control the brightness of your unit
3helpful
2answers
Dark picture (HELP)
Open up the back of the set but be very carefull. Notice a large black block with a large red wire that runs up to the picture tube. on one side of that large block where the thick red wire is comming out of are two controls, one should be marked focus or F and one should be marked screen or S. With the set operating normally and not touching anything else, slowly turn the control marked screen or S clockwish till the picture gets bright enough. If you go too bright the set will shut down or you see small thin white lines so back down on the control. then touch up the focus and your good to go. good Luck.
2helpful
Toshiba 35A44 - Dark picture on all channels and DVD's
for this brightness problem actually came out from flyback transformer...so, before you spend and waste your money, try to adjust at back of your tv first. But if you aren't an expert, better ask technician to do because that transformer supply a very high voltage....there's two adjustment point at flyback transformer, one point for focus and the other one for brightness! try first...
Top GE Televison & Video Experts
ExpressFiX
ExpressFiX
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
