Are you wanting to disconnect the shift rod from the lower unit?? It just unscrews..
..getting it screwed back in and set to the CORRECT HEIGHT is EXTREMELY IMPORTANT..(if you want to be able to shift and make the lower unit to last!)
get one of these,, its invaluable!!!
Johnson Evinrude Manuals 1917 2007
SOURCE: how to remove shift rod linkage to pull lower unit
goto local library get book on unit!!! :)
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
