Question about Kenwood Food Mixers
Speed control swich on Kenwood Titanium mixer
Speed control switch on Kenwood Titanium mixer only works on fast speed.
The switch on the titanium has a flimsy week point and is always breaking. This is a stupid economy by Kenwood when there is now so much good competition. Mine broke after only 6 months and Kenwood were less than helpful suggesting I took back to where I bought it - 500 miles away!! I wish I had bought a Kitchen Aid
Posted on Jul 04, 2013
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Blakeslee (Kenwood) A717 mixer speed control
I had the same problem. Had to strip the machine down to get to the motor. On the top is a moving plate with various capacitors etc mounted. On the front side there was a Capacitor (At least I think it was) with the wire broken.
I resoldered it and the machine now works fine.
I hope this helps
Posted on Jul 05, 2008
mirran
Mirko Blas
  • 515 Answers
SOURCE: Blakeslee A717 speed control
where are you from, i have phone number to agents that still provide support for A700 series.
Posted on Jul 12, 2008
Anonymous
SOURCE: Speed switch gone beserk
ANSWER
I have a K5-A, bought it for my S.O., she makes Krispy Cream doughnuts with it. The speed controller on a K5 has "originally" 2 return springs. They rust / break fall out the lower vents in the white cup that covers the rear of the machine. You can remove the cap with the removal of the lone screw at the top rear of the machine. Just gently work off the cap after the screw is removed. MAKE SURE THE MACHINE IS UNPLUGGED FIRST!!! There is a funny metal flange thing that is mounted with two screws at the top on springs. This is esentialy the speed controle. It is actuated by a rod conected to the outside switch that runs up the bottom of the motor drive. You'll note the simple but effective off / on switch there. When the springs rot the funny flange thing does not return to its flat resting position and we have no low speeds. The springs attatch to the holes on eather side of the flange and stretch down to a post type mount below the speed mechanism. If you use a good light you can see and mount any small spring to these mounting points and the switch returns to rest and you have all speeds, a single light spring will work.................There, You, Go..........Reassemble.
Posted on Dec 13, 2008
Anonymous
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
Kenwood Major Titanium KM020 speed setting stuck at maximum
Send me your email, I will send you some info
Regards
Nov 02, 2012 | Kenwood Food Mixers
Kenwood Chef - slowest speed
if you have max speed you have to replace the .1uf capacitor the 2 spring loaded screws serve far fine adjustment
Feb 02, 2009 | Kenwood KM400 / KM410 Chef Classic Stand...
Speed control not working
What model is your Kenwood ? to Kamalsalman
A901 models change triac and capacitor .. or centrifugal broken
also check if another's components is faulty.
Kenwood Chef Restore
Dec 22, 2008 | Kenwood KM800 Major Classic Stand Mixer
I hope this helps
Jun 28, 2008 | Kenwood KM305 Stand Mixer
Speed control not work - constantly on high
The resistor will have failed. The A701 replacement is a 450 ohm 15W or 20W wirewound resistor. The capaicitor also can fail if the resistor has gone. It is a mains capacitor 0.1 microfarad. The modern mains capacitors are better to use than the old electrolytic type that were originally in the mixer.
Jan 01, 2008 | Kenwood KM800 Major Classic Stand Mixer
Food Mixers Logo
345 people viewed this question
Top Kenwood Food Mixers Experts
Peter GW Fleming
Level 1 Expert
Treefrog15
Treefrog15
Yitz Diss
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
