I have a samsung ln-t4071f tv and when I hit the power button on the remote, the screen goes black but the blue light power indicator under the screen and the red power light on the side of the screen remains on.
I tried unplugging the tv but when I plugged the tv back in, both lights came back on. When I hit the power button again, the picture came back on.
I recently tried to adjust the settings (color,contrast,etc) so I am thinking that I triggered this when I changed the settings. I would appreciate your suggestions.
The device sources and the inputs have not been set to the correct mod.There could be a problem with the TV it's self for it to be turning off like a problem with the power supply for the TV.
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
To replace the screen is going to cost about at least $500.00. I will try to sell the tv as is for parts. You can probably get about $100.00 . Thats how much I buy them for.
This normally causes by failure of power supply board. Some time it causes by failure of inverter board, in this case you can see the picture moving on the dark screen as it has no back light.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
