what is it< must I google to find out what it is?
ok,,,
did you buy it used and broken,? if yes read the manual first.
The
Traynor TVM50 battery powered amplifier is designed for the musician on the move
posted to computers and is not one.
the batteries must be recharged and not connected backwards
if the charger inside, is bad then so will be the batteries dead.
im reading your manual now , and it tells me.
quote
This LED illuminates when the amp is being charged. Once the battery is fully charged, this LED will dim and turn off.
The battery requires 24-hours to be recharged properly.
more
2. For best performance, ensure that the TVM50 is switched off while the DC charger is connected. The TVM50's battery charging system is not designed as an AC power source. Operate on battery power only. ,<<< see this?
3. The TVM50's battery is lead-acid based and should never be fully drained. If the TVM50 is in storage it is recommend to recharge the battery at least every 1 or 2 months.
, the manual is free.
here
http://traynoramps.com/guitar/tvm/product/tvm50/
