You can transfer pictures from your phone to your computer in 2 ways. Bluetooth
1. Enable Bluetooth
- From idle mode, select Menu > Settings > Connections > Bluetooth.
- Press the OK Key to set Bluetooth to On.
2. Pair your phone to your Bluetooth enabled computer. If your phone does not have a built-in Bluetooth module, you can buy a Bluetooth dongle from your local electronics store.
- From idle mode, select Menu > Settings > Connections > Bluetooth > My devices.
- Press the OK Key to search for available Bluetooth devices.
- Highlight a device from the list and press the OK Key.
3. Select your desired file, and select Left Soft Key [Options] > Send > Via Bluetooth.
4. Select the target device from the device list, and press the OK Key to send. Email
1. Select your desired file, and select Left Soft Key [Options] > Send > Via Message
2. Enter your email address. press the OK Key to send.
3. You can now download the file from your computer.
look under tools or settings on your girlfriends phone and turn on the blue tooth. you must be close by with your bluetooth turned on also. you must "pair" the two together,(connect) choose to the "pairing option" on either device and a request to pair should be approved. usually the pairing code 4444 will work, use it and when your paired go to your message and send music via bluetooth option... hope it works...
Verify that Bluetooth is turned on or enabled in both your devices. Most cell phones will have a Bluetooth menu in their Settings or Tools. For computers, you may see a Bluetooth icon in your system tray. If unsure, check your product manual for specific instructions.
Follow the instructions to pair (connect) your two devices. If you are asked for a passkey, try entering 0000 which is usually the default for any device.
When prompted on the other device, give permission for the original device to access it.
If transferring from phone to phone
Navigate to the song you want to send and hit the button that takes you to the options menu. Choose the option to send your song; depending on the brand of phone it may say "Send" or "Move."
5
The next menu should ask if you want to use a text message or Bluetooth to move or send the file. Choose Bluetooth.
6
When prompted on the phone receiving the file, accept it.
If transferring from computer to phone
7
Look for an option to browse the contents of the phone. Navigate to the Music or Multimedia folder on your phone.
8
Navigate to the place on your computer where your music file is kept in a separate window.
9
Drag the file from its original location to the correct folder on your phone.
10
Accept the file when prompted by your phone.
Tips & Warnings
Pairing is usually the most difficult part of the process. Make sure you read your manual on both devices if it isn't working for you. If you don't see the menu to move or send your music, your phone manufacturer may not allow it. Check your manual or with your carrier's tech support website. This process usually applies to MP3s and not ringtones.
Go to the photo you would like to send, select the option to send via bluetooth. Make sure the other device is near and has bluetooth on. Select that persons bluetooth signal and follow the prompts to pair/send the image via bluetooth.
HELLO FRIEND
SELECT THE PICTURE AND PRESS OPTIONS
THEN GO TO SEND OPTIONS THEN SEND VIA > BLUETOOTH>SEARCH DEVICES>EXACT DEVICE>CONNECT>ACCEPT>SEND
TO PAIR
BE SURE THAT YOUR DEVICE IS NOT IN THE BLOCKED DEVICE LIST ON THE OTHER DEVICE
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem.
Hope this information assisted you!
To do that, both your phone and your PC must have bluetooth (why don't connect your phone to PC via cable?), turn on bluetooth on PC and your phone, pair them and start send pics via bluetooth!
hi friend,
You can go to your album, and select the picture and click Options>Send. Then a small window will pop up and ask via Picture Mail // via bluetooth. You can pick bluetooth from there... Or you can go to the memory card manager through the phone (Mass Storage>File Manager>(phone//memory card)) and from there you can press options and you scroll down to which ever you want to send! good luck!
hope this helps u
please rate me........................
thank u for using fixya
regards
sivaranjini
There is no send option in the options menu. I know the phone has bluetooth because i have paired it already
