I ran ir through a santize cycle yesterday and now it will not stop running water through it!
SOURCE: Front loader will not spin
You will have to get it repaired that's the only solution.
there being a bad connection wire between the motor and the control board.est the fuse(s) on the control board. If they are bad, then the control board is in need of replacement.
Goodluck,
Please don't forget to rate the solution
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
SOURCE: frigidaire top load washer approx 6yrs old water
The problem is your water inlet valve has failed. It is stuck in an open position. Part # AP3267279 at www.appliancehelponline.com
cost is $37.87 easy to replace. Remove top cover to acess.
SOURCE: frigidaire model fex831fs2 stops after
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin
then you can check if the lid switch is fine. You can jump start the lid switch
by connecting both the wires with each other or use the third wire to act as
jumper between the two. After this if the problem is solved then replacing lid
switch is recommended repair, if you are sure that the lid switch is fine and don't want to do the above test then I believe the Timer is bad and needs replacement. Please get back to me if you have any other
questions.
Kevin
