I have had this psp for a while all it does when I try to power up is the green light comes on for 3-5 seconds then turns off I dont hear anything no sound. This has gotten pretty frustrating can anyone help. The system was used for about 3 months then just stopped working by itself.
eddie
south texas
Hi Mairyandgabr.
this is all i could find.
try this link to a forum.
MY psp won turn on other symptoms PlayStation Nation GameSpot
or this one.
PSP won turn on no lights at all
or this .
PSP Won Turn On
PSP Console won power up Google Search
SOURCE: psp green light on but now screen
Try Holding the R trigger and turn the power on at the same time. This puts you n a diffreent mode, then press the display brightness button to see the version. Power off and back on agin to see if that resets it. This is only a guess I would appreciate at least a thanks for trying.
SOURCE: PSP Won't turn on
Try this>
Start with the PSP turned off. Press and hold the R button when your turning on the power. Turn it off again, then back on. Sometimes this works. If not, your PSP is probably Bricked.
This means that you done something to interupt an upload or program in progress. The eeprom program is corrupted and the PSP will not boot up. The term Bricked, refers to your PSP being no better than a black Brick paper weight. I have heard of a repair for this called Pandoras Battery. I am not sure if the Pandoras battery really works to restore Bricked PSP's. It may be worth a try for you to take a chance on Pandoras Battery.
SOURCE: My PSP wont read my battery
Try putting it in a bag of rice for a day or so, because rice absorbs moisture, so it might draw out any water still inside. Hope this helps.
SOURCE: my psp will charge but wont turn on
You'll need to visit a repair personnel to fix the PSP, the screen is damaged from you problem description.
This is the only way out for you.
Regards
Hi Gohan102,
Open the battery compartment, and remove the battery. Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light, If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp. If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment. Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
