Indesit W 123 Front Load Washer Logo
A
Anonymous Posted on Feb 01, 2018
HiTo all iv been having problems with my dishwasher its a indesit aaa class idf 125 it keeps turning its self off then there is no power at all iv now had it off fr 3jd mounths and now its working again this happens fr about 5 washes the the power will got off till october lol can someone help
southside773
Level 2:
Novelist:
  • Expert 108 Answers
  • Posted on Feb 03, 2018
southside773
Expert
Level 2:
Novelist:
Answers
108
Questions
Helped
13249
Points
245
Could be anything but check your water heater element first - prime cause of power tripping. Also check for leaks from the sump into the wash motor / electrics etc Usually manifests as fills, runs for a bit then cuts out as leak starts. Be very careful with electrical safety on this one - water and electricity are a deadly combination. ensure the power if off, and machine unplugged before examining. test for safety after the repair.
3 Related Answers
Anonymous
  • 417 Answers
  • Posted on Feb 10, 2008
SOURCE: Indesit WG635 TP power light on but not working
sorry program board my friend replace.
Thanks J
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Feb 12, 2009
SOURCE: indesit idf 125 dishwasher
you don't need salt in the dish washer?
Owen Barnes
  • 867 Answers
  • Posted on Mar 07, 2012
SOURCE: I have idf 125 indesit dishwasher i fitted a new water solioned but it will bring in water but pumps it back out and lights flash what is the problem
These machines use the wash motor to measure the water level.they measure the load on the motor which tells it when the water has reached the correct level.
Your dishwasher is sensing that there is too much water, they are a semi timed fill. try turning the inlet tap down a little and see if that helps.
If not the issue is either in your electronics or in the motor, The electronics sometimes get dry joints and if you have a soldering iron they are an easy fix.
How do I Fix upper spray arm to Indesit IDF 125 UK
It depends a lot on what is wrong with it. You can get special glues that fuse plastic if it is broken.
If you need to replace it, appliance spare parts are available online.
If it is intact but still non-functional, try taking it apart to see if something is causing it to bind.
Past this, your complaint should direct the course of your remedial action. You did not say what was wrong initially.
Good Luck,
Pete
Indesit idf 125 dishwasher
Indesit IDL 530 Dishwasher
Switch off, turn off power, turn off water, disconnect water inlet hose, check for blockages, remove filters, clean filters, refit filters, check water supply, reconnect water supply, reconnect power, turn on - problem solved.
Top Indesit Washing Machines Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Sean Wright
Sean Wright
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
