Start up computer in safe mode and monitor works. As soon as I try to load windows XP the monitor goes to a box with this message. DSUB, Input signal, Out of range. Counts down 20 seconds then shuts off... Any help??
SOURCE: Computer goes to blue error screen 0x000000FC
Hi!!!!!
try to open up the tower
check the ram of your computer
try unset it and clean
and put it back properly!!!
if it is happen again!!!!
and try re-installe your video card
and if it is happen again!!
try to diagnost or surface scan of your harddisk if it has a badsector
it it is happen again try to reformat your
your operating system if you know how
to format and buck up all the files that u need
and if it is happen again in again
try to replaced your
Ram must be on the same speed or borrow from your friends
or
the hardisk may be had a bad sector try to bowrrow from your friends
try it!!!!
good luck
SOURCE: After loading Window service pack 3 update, comes up blue screen
i think theres a spyware or u have to repair ur windows
SOURCE: trying to restore dell 4400 and cannot get to a dell screen for f-12
If you boot from the XP CD and choose the first repair option it will load to a DOS prompt. From there type "chkdsk /r" and press enter. This will run checkdisk on your hard drive and repair any problems that it finds. It will take 45 minutes or more depending on the size of your drive. Once it finishes type exit to reboot and remove the CD. Your computer should boot normally.
SOURCE: My Dell Dimension 4400 running
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
SOURCE: pc keeps loading and restarting again, it wont go past windows xp
well,eventually if it started several times the good configuration you will take is that also to restart again,it better to move on to safe mode in order to restore your windows normally that process will restore your some missing file to start up.after windows appear.
click start,click all program,click accessories, click system tools,click system restor until system restore appear just select any date that system restore will correspond to your request( I prepare past date)then follow the restore system what to do until it will restart again your PC Observed there will a long time to restart just let it be make the restor system is fixing your start procedure then finish it will now appear your refresh windows.if you shutoff and start again it will put back to normal operation.If the problem occured again some virus is inside your hardisk reformat your windows.
