Panasonic TH-42PX60U Television Logo
Anonymous Posted on Dec 08, 2008
TH-42PX60U red light blinks 10 times wont come on
My tv does not come on. I replaced one fuse. Nowq it blinks 10 times but wont come on. Help me!
  • 15 more comments
  • Anonymous Dec 10, 2008
    same problem
    I looked into what the problem could be and it points to 3 diferant boards. pa,dg,and h
    i dont want to have to buy all three
    can anyone shed some light on subject
  • Anonymous Dec 17, 2008
    The solution is to not buy Panasonic again or get the extended warrenty. My 10 blinks and pause Panajunket will sit bundled up while I watch my new Westinghouse 47" LCD. PJ is only 1-1/2 years old and used to watch DVD's only. Oh, and the rattling vibration when the sound turned up, not blasting sounds.
  • acewayman Dec 23, 2008
    My husband was watching his TH-42px60U and it just went off, blowing a circuit with it. My husband fixed the circuit, but the TV won't come back on. The power indicator light blinks 10 times. My husband called Panasonic Support and was told that this is a service issue, and a TV service repairman will have to be called.
  • Anonymous Jan 06, 2009
    my pany does the ten blink code with no inputs plugged in no rca's, no hdmi's no component hd cables just a power plug. still blinks ten times
  • Anonymous Jan 30, 2009
    i have the same problem... it blew the 2 fuses. i put 2 new fuses in it and know it blinks 10 times with nothing hooked up.  any ideas?
  • Anonymous Jan 31, 2009
    i popped 2 fuses and have the blinking 10 lights. anyonoe know what board to replace, the pa or h? anyone know where i can get them??
    I had the same problem and it was a bad power supply board! If you can't afford to have it replaced I was asking to purchase your set. I just really needed the display panel but will purchase the whole thing if you so desire. Again, I had the same symptons and the problem was a bad power supply board.
    Thanks for asking.
    Nebster
    power supply board? is that the same thing as the pa or h board that the service manual is telling me with 10 blinking lights?
    i thought the power supply board is something different.
  • Anonymous Feb 14, 2009
    i have the same problem and i can't even find the fuses but looks like even after replacing the fuses the TV is still not coming on for people....let me know if someone has any luck with it
    thanks
    hey mmalignaagi
    would you be willing to share your manual or tell me where you downloaded from
    thanks
  • Anonymous Feb 20, 2009
    so far i replaceed the dg, h and pa and still havn't fixed it.. im going to try the p power next.. What do you guys think?
  • Anonymous Feb 24, 2009
    nebster,
    I checked the resistance on the two white ceramic resisters and one doesn't have any resistance. It most be the power supply board. I will post my outcome soon.
    Thanks for your help.
  • rooski23 Apr 30, 2009
    I have the same problem with the 10 light indicator. Which board should i look to replace?
  • rockytorres May 11, 2010
    Panasonic th42px600U. 10 blinks - my son checked so-blo fuses > OK, Checked power supply board no visable problems. Still 10 blinks? What's next PA or H Boards? Thanks for your time >> Rock
  • Anonymous May 11, 2010
    Is the power supply board the same thing has the pa or h board.   the service manual is telling me blinking 10 times is either the pa or h board...
    anyone fix there sets? I still have 10 blinking lights. I might try to buy the pa and h board. i have the service manual that costed me 12.00 that i downloaded. It says board pa or h is the problem. What do you guys think?
  • Anonymous Mar 23, 2014
    no picture on tv, light blinks 10 times, stops before restarting to blink again 10 times
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12522
Points
11
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Anonymous
Level 1:
  • Posted on Jul 31, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
12522
Points
My TH-42PX60U power went out suddenly as well. I replaced the fuses (after removing the rear cover panel) and then saw the 10 blinking power light. Blinks 10 times, pauses, blinks 10 more times and so on. I replaced the power supply board, good price from River Valley Electronics, and that solved the problem. TV is back on line. I took a chance that this might solve the problem after seeing that advice from another post. Cheaper than buying a new TV.
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
15385
Points
33
Well the problem was solved with a simple kit i found online
there was a open 10ohm resistor and a shorted transistor. Q406- transistor and the R410 resistor take a dvm and test them on your psu. if you have decent soldering skills im sure you can repair your tv your self for well under $40.
  • Anonymous Oct 04, 2010
    Where did you find the kit at?
Anonymous
Level 1:
New Friend:
  • Posted on Nov 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
12522
Points
What is the model number for power suppl bpard panasonic th-42px60u
Anonymous
Level 1:
New Friend:
  • Posted on Apr 11, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
12522
Points
When i turn my th-42px60u panasonic it has a black square screen in the middle of the screen leaving a 4 inch border with the picture visible... When i push the menu button it disappears and i could see the picture. If i push menu again it re-appears.. After 10 min the tv will shut down.. Then the led light will flash 11 times...
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 03, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
13769
Points
I replaced the power supply board and the tv works great!!
Thanks Nebster!
  • Anonymous Mar 03, 2009
    I replaced the power supply board and it works great. thanks nebster!!
Th42px60u
Most likely is the power board,so I hope you got a good one! The next would be a short on the SC board. The main digital board could be defective in mis diagnostic. Disconnect the SC board and see if the blink code changes. if it changes,the main board is good. If you have a good power board,I vote for a short on the SC board to be checked
Tcp42x1 wont power on, red light blinks 7 time
hello, one thing that is good is that these panasonics have a safety fualt feature the light blinks and the number of blinks indicate what board is affected. the best way to find out what to exchange is by aquiring a service manual for your brand and model tv then review the service manual it will tell you according the the blinks what to replace or what board is bad..hope this helps..
The red light is blinking 10 times but the TV doesn't come on
is fatal error. control board dead or some device connect in sleep mode and sets tv allways in sleep mode
TH-42PX60U wont turn on. Blinks 10 times. replaced the power supply board, but the same issue.
What I'm learning is there are several models of Panasonic TV's that have a video card that doesn't play well with HDMI applications and the end result is, you need to call this number and not only make arrangements to replace the bad board,but also this!
Your model doesn't show below,but I'd certinly inquire about the necessity of a "Firmware" update!,,,Panasonic knows FULL WELL they have a HUGE problem here!
Hope this helps!
At panasonic.ca I found the listing for the fw update under customer support-important notices
If you own a plasma TV with model and serial number within the range specified below, please contact our toll-free VIERA Concierge hotline service at 1-866-330-0014. A VIERA product expert will arrange an in-home software update for your TV at your convenience.
Model Numbers Serial Number Range
TH-42PZ77U
TH-42PZ700U **71250001 ~ **80189999
TH-42PZ700UA
I have the same problem Panasonic Plasma TV wont come.
Alot of times capacitors on the power supply circuit board will go bad. They will bulge/dome or dry up which will cause this problem. Bad caps dont hold a charge, which is needed to maintain a voltage. The circuit board is two sided which makes replacing the caps difficult, and the board can be damaged and have to be replaced. Taking it to a repair shop may be cheeper and safer then doing it yourself. Having two-six caps replaced is a lot cheeper then a new board.
4helpful
2answers
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
2answers
TH-42PX80U
i have the same problem but i have 11 blinks
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
