SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
SOURCE: receiver - onkyo tx-sr606 problem
I had the very same problem tonight (no speaker setup menu (2)) and was about to do the reset as suggested by other poster... but then I noticed that the front of the amp was showing DIRECT just below the DD sign... this got me thinking that there must be a correlation between the DIRECT sound setting and the lack of speaker setup... (sound was only coming out of the FR and FL speakers - no surround and no Sub)
Essentially to fix this I had to review all my settings for the inputs and (iirc) the audio settings....
Long and short of it is that I was able to sort the problem without resorting to a full reset... I am a total newbie to all the AV amps and settings etc ... so am still playing with it so-to-speak
Hope this helps
SOURCE: onkyo tx-sr606 hdmi problem
Yes the OSD tends to stop working. Here's how to fix it:
http://www.youtube.com/watch?v=gj0x5S9ez5U
