I had inserted my sim card incorrectly and my pictures went to the cameras internal memory. I have removed the sim card and tried to print them but I keep getting message no memory. I would think I should be able to transfer the images from internal memory to my sim card? Hope you have the solution? Thanks Carol
SOURCE: Camera will not read memory card
Make sure you format your memory card before you try to use it other wise it will save the pics to ur internal memory instead of the mem card.
SOURCE: Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
SOURCE: Resetting EX-V7 error message
Hey Go here
http://world.casio.com/qv/download/en/ex_v7_firmup/
Download the latest firmware. Install it. Like the rest of the people. It seems like we all dropped it. And updating the firmware seems to help a bit.
Meaning you can now use tha Camera and take pictures, but when you turn it on, you will get the same error message for like a second. Then the Camera is back to normal.
If its under warranty take it back. And dont tell them it was dropped.
Cheers !
SOURCE: casio exilm ex-z80
well its obvious tht the card must be locked so slid e the thing over to unlock it n it should work :)
SOURCE: I lost the download cable for my Exilim camera.
This procedure will copy all files from internal memory to a memory card.
1. Load the memory card to which to copy the files.
2. Turn on the camera, enter the PLAY mode, and press the MENU button.
3. On the "PLAY" tab, select "Copy" and then press right-arrow.
4. Use up/down-arrows to select "Built-in->Card" and then press SET.
Wait until the Busy message disappears before doing anything else. After the transfer the last file transfered will appear on the display.
Testimonial: "Exactly what I needed to know! Someone had told me my camera could do this - I searched and searched but couldn't figure it out. Thank you FixYa!"
