Hello here is the homepage:
http://www.mercury-pc.com/product-detail.php?link=p-mainboards&subtitle=Mainboard&productid=718#
The mainboard is socket LGA775 for latest Intel Core 2 Duo(E4400/E4300)/ Pentium(Dual- Core inside)/ Pentium D / Pentium 4 / Celeron D processor/
Good luck
SOURCE: i need pi945gzd sound driver for my system please help.
Yes, go to the manufacturers website and type in Drivers in their search box. Then they should ask you for your make and model and show you where to download the drivers.
SOURCE: driver for Mercury Mainboard PI945GZD
You have intel chipset on your motherboard.So following are the links to download your motherboard drivers.
For Chipset and Graphic driver Click on following link and download drivers for Intel 945GZ Express Chipset.
For Audio Drivers Click On following link.
Audio Drivers
Don't Forget To Rate !!
Thanks
SOURCE: f672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Testimonial: "my current processor is intel pentium dual core.i'll get a core 2 duo with 800mhz or less.thanks"
SOURCE: will this mobo support an Intel Core 2 Duo 3 GHz
Yes it will support Core 2 Duo 3.0GHz and higher. Open the link provided by ECS and choose you're CPU speed; http://www.ecs.com.tw/ECSWebSite/Support/CPU_Support_Model.aspx?detailid=672&MenuID=69&LanID=0
ECS link to 945P-A (V3.0); http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=672&DetailName=Feature&MenuID=52&LanID=0
Cheers'
Mike
Testimonial: "thanks, Mike! "
SOURCE: how to overclock foxconn g41 mxe motherboard?i
ur overclocking depends on ur memory if u computer takes max mem, of 8 gig do 10 memory overclocking is much safer than over clocking mhz
