I have a 20 year old Jenn-Air cooktop that never had a seal between the glass and the counter. I recently had quartz countertops installed and the installer says I need a fireproof double faced mounting tape to seal the class cooktop to the new counter. Where do I get that?
SOURCE: i just bought a 7904427 electric kenmore cooktop,
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - [email protected] - http://.www.StoneRepairman.com
SOURCE: Replacing an old jenn air
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
[email protected]
406.471.0000
