Cover replacement?
This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:[email protected],we sincerely hope we can help you!
you can also check this boards whether suit you:
9721AQKM 715G3350 1 3 Acer ADTV9721AQKM Power Supply Backlight Inverter
HI You can try with the helping pictures I collected from the links below. I hope you can find some similar techinque. 1) http://www.daydeal.com/pages.php?pageid=5 2) http://repair4mobilephone.org/disassembly_motorola.html Actually, the hinge removal of Motorola phone is the most difficult task. You have to be carefull or else you will brake the LCD cable since the connector of the other end of the LCD cable is located near to the hinge. If you applied too strong force there, you wil brake the LCD cable easily so to me, in order to remove the hinge, you should disconnect the both ends of LCD cable connector. One end will attach to the main LCD near to the speaker, the other end will connect to the main board. Disconnect both of the end in order to release the pressure when you apply on the edge of the hinge in order to seperate the LCD part and the main board with keypad part. Good luck. Regards, Joseph
