Coghlan's CTech Wireless Weather Station Weather Gauges Instruments Logo
Magda Opperman Posted on Jul 05, 2012
C Tech Weather Station. How do i reset the outside temperature. Meter says it's off?
AS of SA
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 22, 2016
AS of SA
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
747
Points
Is the outside unit LED on? I replaced the battery on the outside unit and in doing this reset the outside information.
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
Auriol radio controlled weather station keeps losing outside temperature
My monitor has a solar panel on outside unit and if you do not use chargeable batteries, because the the regular batteries will not work Good Luck
1helpful
2answers
Outdoor temperature on indoor station showing - -.
Check the battery in the outdoor unit, resync them per the instructions, if that does not work check for interference.
My weather station is no longer recieving an outdoor temperature reading. The barometer is working fine, as is the indoor base station. Both were given new batteries at the same time, and the set up i
hi,
does the outside humidity working ?
if yes - the outside station is transmitting but the temperature sensor is faulty,
if no sensing is available from the outside station, it look like the outside station is faulty . (this is common because of extreme weather change.
notice that the pressure sense is done in the base station.
regards ,
Daniel
https://www.rylwy.com/
Next tech weather station is. Not w
Try taking the inside unit outside as close to the transmitting unit as possible for three minutes. The signal might lock on to the setting you want to receive.
What's your problem?dr. Tech WH-1170T User Manual
how do I change the time to regular settings from 24 hour.
The sensor from my weather station is not registering outside temperature
I've had the same problem since I bought this unit 2+ years ago; when the outside temperature moves into the freezing zone, the sensor stops transmitting. I contacted Lacrosse-- all they could suggest was change the batteries. My solution: throw it in the trash!
Top Coghlan's Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Coghlan's Measuring Tool and Sensor Expert? Answer questions, earn points and help others
