Please am seriously having this issue which troubles me a lot, i always get this on phone start-up " phone start-up failed please contact retailer" and i have done the 3 key hard reset and also have flashed the phone but the problem still remain the same, please what should i do?
SOURCE: Problem is""phone star-up failed. contact the retailer"
The best solution for this problem is to format the phone memory. U may think format will erase all applications but it is false . The essential softwares like mp3 player, camera, etc. are not erased.
The process for format of phone is :
1) turn off the mobile.
2) press and hold ( green dial button + 3 keypad + * ) and turn on the phone holding these 3 buttons(dial button + 3 + *) until formatting screen appears.
3) When formatting screen appears, just leave the keys. and ur phone is formatted now.
4) When finished, it asks for restart of phone.
5) Restart ur phone, and ur phone is ready.
SOURCE: Start-up Failed Contact retailer
try this tricks....
If you encounter situation like below on your 6670,
1. Blank screen phone unable to reboot.
2. Phone only able to boot-up to "Nokia" word screen.
3. Install some program but not able to uninstall it after that.
4. Error messages such as "Child Installer" keeps popping-up.
Do a Full phone formatting on your 6670! as steps below,
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your 6670phone.
4. Press and hold 3 keys;
Green dial key, * (star key) & no. 3 key and then press the power on/off to swtich on the 6600 phone.
Remember, do not let go all of the keys and hold keys until you see a NOKIA turns to white screen LCD!
5. After a few minutes when the Full phone formatting completed, your 6670 will back to original system and factory settting.
All apps installed & not of the phones' default will be lost. If you did a backup on your mmc, you can restore it back to the C drive again.
but still you have the prob. Contact Re-tailer
go to the Cellphone Shop nearby and try to re-program your mobile or Hardware...
Thank you for rating this Tip.
SOURCE: how can i reprogram my nokia 6680 manualy
i know how to re program the phones without any wires.
SOURCE: need to formatting nokia 6260 mobile
Switch the phone off. Hold the following 3 keys down and turn on:
3 , * and the green phone key
This will reset back to factory defaults but will completely wipe the phone of all data (your contacts, messages etc). Just follow the onscreen instructions - it will prompt you for your security PIN, the default is 12345. Good luck.
SOURCE: My nokia 3230 failed to start up. when i turn-on
My nokia 3230 failed to start up.... Answer Failed: retry My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which... (More) (More) My nokia 3230 failed to start up. when i turn-on the button it wll only show the phone brand which is Nokia then a message will appear on screen which is "phone start-up failed. Contact the retailer." can you offer me solutions for this?
