1998 ford contour will start with starting fluid but wont stay running
Without seeing it here is my best answere, do you have the ability to pull codes if the cam and crank sensors are functioning properly ( no codes for them) i would then check the fuel pump fuse and relay . do you have fuel getting to the fuel rail . if u have a guage to check pressure at the fuel rail it should be above 30lbs , if you have no pressure and your fuses and relays are good then you have a pump problem provided you have not been in an accident , i believe that vehicle has a safety shutoff that might be located in the trunk .
