My Hotpoint Washing machine stopped in middle of cycle. I noticed on an answer for someone else that you mentioned a sensor switch undernesth the door. How can i check this? If it isn't the switch, what else can I check?
Regards,
Brian Forbes
Theres two type of switches , the magnetic and the standard switch with the little hook , you need a multi meter tester , set meter to OHM and check the two leads that connects to the switch, while the tester is connected close and open switch , if meter reads 0 then switch is bad.
try to clean switch with a TUNER CLEANER by RADIO SHACK and try again . hope this helps AJ
