My senseo coffe maker the lid is stuck shut will not open what do i do
I just had this same problem. The seal is stuck and might have coffee jammed in it. I unplugged it. Then I pushed down on the lid and pulled up at the same time. It opened for me. I hope this helps.
The small hole in the pod tray is stopped up and causes the unit to vacuum seal. This can happened to me when I got a bag that had a lot of coffee dust. Give it a while (maybe as much as a day) for the vacuum to release some to get the top open. Clean the small whole on the pod tray - I think I used a needle when it happened to me.
mines stuck shut its been 24 hours anyone got anymore ideas
It really helped! Thank you!
IT worked!!! Thank you. Let me give ya a smooch :)
The Phillips electronics web site says that pod tube is plugged and now a vacuum has been set up preventing you from opening. It says "unplug it; leave it at room temperature for 24 hours or longer and then try to open. It states you may have to apply a lot of force to get it open. Once you get open clean the pod tube regularly to prevent this from happening!!!!!! Only use recommended pods in the coffee maker. Go to
I had a same problem, but I managed it open without waiting 24 hours by turning and slightly pulling a small plug behind the water tank on the back side. (see the photo attached) I think it will let air goes in and release the vacuum seal. After I could open the lid, I turn the plug back and push it in as it was. Now, my Senseo is running perfectly again.
I have no solution ive tried everything but nothing is working HELP
Place machine upside down in a bowl with about 2 inches (50cm) of hot water. Normal tap water temperature should do. Wait a few minutes then pull the lever. Hopefully the lid will open, mine did.
I just had the same problem and fix it.
Here what i did :
i sucked the water tunnel on the back side of the machine. ( you will unplug the plastic thing just by the hand)
P.S : watch out the water sucked may be a little bit hot , so it’s better to wait a little bit after the water get cold.
P.S_2 : im not gay for all that sucking things.
I can't open the lid. The lever works ust fine but the lid doesn't pop open. I put as pressure as I think it can take but no luck!
