Nokia 1616 Cell Phone Logo
Rajivsinha Posted on Jul 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Switched off after fallen from a height unable to switch on
Jordan Raingam
Level 3:
  • Nokia Master 2,148 Answers
  • Posted on Jul 05, 2012
Jordan Raingam
Nokia Master
Level 3:
Answers
2148
Questions
Helped
506564
Points
7940
Hi before you buy new one at least change the LCD by contacting mobile repairing shop.Frequently when this model dissorted their LCD when it drop down.I too solved dead phone of this very by changing the LCD.Therefore this is my advise you to do it first.Good luck.Thanks for visiting fixya
200z snapper mower blades only engage when deck height button in pressed
My first impression is a ground issue. You might try disconnecting the deck height switch and see if/how the symptoms change.
The wiring diagram shows the electric clutch is energized when the ignition switch is in either run or start with PTO switch on. Testing can be done without the engine running. Check the common ground point.
It won't start when I shut the door
If you have a little switch lever that the door pushes when it's shut, it's possible that a) the door is not closing far enough to depress the switch; b) the switch is faulty or its wires have fallen off. If there is no switch lever, the door is supposed to have a magnet in it the activates the cycle when the door is closed. The magnet could have fallen out, or the magnetic sensor could be the issue.
Brakelightsdonotwork
If your Brake Light Bulbs are good, then what has happened is your Brake Switch has fallen off the REAR of the Brake Pedal.
Test the Switch and it is either Fallen off or it is Bad.
The start bottom will not stay on it does work with something stack in it we change the botton but it does the same problem
If it has a bowl guard on it then the problem could be either the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then the side switch on the contactor is the problem. If it has a bowl guard, make sure the bowl lift is operating the bowl height switch. The bowl must be all the way up to operate the bowl height switch.
1helpful
My h 600 will only run when i hold the start button as soon as i let go it stops
1helpful
2answers
1996 seville rear air ride too high
The ride level system uses an air compressor and either an air type of shocks or a type of air billow to raise and lower the vehicle, there is an adjustment to set the ride height and it is located under the vehicle and there is a control lever or rod that should be connected between the rear axle and a switch that is mounted on the body of the vehicle, and there will be an adjustment slot in the control lever between the switch and the body, and that is how you would adjust the ride level height, but be sure that the vehicle can not drop any further down if someone is under the vehicle trying to adjust the ride height.
However, you might find that the control lever to the ride level has fallen off from the switch on the body or it has come loose from the rear axle, and it is just hanging there not operating the switch on the body that controls the the ride level compressor.
3helpful
Electronic level control not working right in a 1999 cadillace deville, what can i do to fix it?
To begin with, check the "ride level" fuse and make sure that the ride level compressor does work, and you should be able to hear that the ride level compressor is working when the ride level system is leveling the vehicle.
However, you might find that the control lever to the ride level has fallen off from the switch on the body or it has come loose from the rear axle, and it is just hanging there not operating the switch on the body that controls the the ride level compressor, or there might be a blown out air shock or billow, or you might find that an air line from the compressor is leaking and the ride level compressor will just run continuously until it blows out the fuse, and if that is the case you might also find out that the air compressor has burned out from running continuously.
Where can i get a copy of the parts that make up the air suspesion of my 2001 grand marquis. sometime it works and other time it will not.
Vehicle Dynamic Suspension The vehicle dynamic suspension consists of the following components:
  • Rear air suspension control (RAS) module (5A919)
  • Snorkel
  • Drier
  • Air compressor (5319)
  • Air suspension switch (5K761)
  • Solenoid valve (5311)
  • Air spring (5560)
  • Air suspension height sensor (5359)
  • Air line
Visual Inspection Chart Mechanical Electrical
  • Restricted suspension movement
  • Excessive vehicle load
  • Cut, severed, or crimped air line(s)
  • Damaged air spring(s)
  • Height sensor damage
  • Height sensor mounted incorrectly, disconnected, or damaged
  • Central junction box (CJB):
    • Fuse 5 (15A)
  • Battery junction box (BJB):
    • Fuse 8 (30A)
  • Loose or corroded connectors
  • Air suspension switch OFF
The air suspension control module is diagnosed using Super Star II Tester 418-F045 (007-0041B) or equivalent.
The test connector used to communicate with the air suspension control module is located on the RH side of the luggage compartment.
When the tester is connected, the engine is started and the HOLD/TEST button is latched down, the air suspension control module will respond sending a code 10 to the Super Star II Tester which represents "Diagnostics mode entered." If diagnostic trouble code (DTC) 10 is not displayed, go to Pinpoint Test A.
Air Suspension Control Module Diagnostic Trouble Code (DTC) Index
Condition Possible Sources Action
  • No communication with the air suspension control module
  • CJB Fuse 5 (15A).
  • BJB Fuse 8 (30A).
  • Circuitry.
  • Air suspension control module.
  • GO to Pinpoint Test A .
  • Unable to enter auto test
  • Circuitry.
  • GO to Pinpoint Test B .
  • Rear air suspension does not respond to load changes
  • Circuitry.
  • Air compressor.
  • Air compressor inlet tube.
  • Air compressor drier.
  • Air suspension height sensor.
  • GO to Pinpoint Test C .
  • Rear rides low/high
  • Circuitry.
  • Air spring solenoid.
  • Poor ride quality
  • Circuitry.
  • Air springs.
  • Air suspension warning indicator ON
  • Air suspension switch OFF.
  • Place the air suspension switch in the ON position.
  • Circuitry.
  • GO to Auto Test.
  • Instrument cluster (conventional cluster) or lamp warning module (electronic cluster).
  • REFER to Section 413-01A (conventional cluster) or REFER to Section 413-01B (electronic cluster), or REFER to Section 413-01C (natural gas cluster).
Problem in taking snaps & videos
My SE K750i handset has been fallen down from a height of 6ft. It got switched off. and was working well when I started except the camera. even after opening the shutter its not displaying the camera its only showing the wallpaper. Not even from camera menu. So I can't take any snap or video. Please help me as what to do . some times when i am going to the menu it is hanging.authorised dealer told that it has virus.please help to solve this problem
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
