Computers & Internet Logo
Posted on Dec 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Dell Dimension 4400 running windows XP Home Edition stopped working and displays a blue screen with the following message: STOP: c000021a {Fatal System Error} The windows Login Process system process terminated unexpectedly wath a status of (0xc0000020 (0x00000000 0x00000000). The sytem has been shut down. I already have tried to restart in Safe Mode but the screen starts to boot up in safe mode by printing alot of code then the screen goes black and returns to the blue screen and the above error code.
  • Anonymous May 11, 2010
    Hmm, did u installed any hard or software latly?
    If you installed any hardware revove it
    If not, i sugest you downloag the program "memtest86" burn it on a cd the boot up yur pc from your cd whit that disc
    Mentest86 will check so your memorysticks are ok
    any errors on a memostick can cause your that blue screen
    u can download memtest86 from here, download the free one
    http://www.memtest86.com/
    Let me know how it goes
Anonymous
Level 2:
  • Expert 107 Answers
  • Posted on Dec 08, 2008
Anonymous
Expert
Level 2:
Answers
107
Questions
Helped
76886
Points
272
If that is not it reistall and to not loose you files click you partion durring the install and do not format it and click enter then click on leave partion alone
1helpful
Blue screen error STOP: c000021a {Fatal System Error} The windows logon process System process terminated unexpectedly with status of 0x0000005 ( 0x00000000 0x00000000). The system has been shut down.
It appears that your Windows Registry is corrupted. You can try to use a Registry repair utility like CCleane to fix it. If that doesn't work you will have to reload Windows OS (Operating System). For more info no this error code Google "c000021a".
2answers
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
I have a problem on this cod c000021a fatal system error i have window when i shut down my computer show blue screen with this cod c000021a fatal system error and computer restarts i need help for solve...
Blue Screen system error. If you've been running windows Xp, please do the following:
1. Insert Windows XP CD in the Pc.
2. Restart the PC and while in Bios, go to Boot Priority and select Boot from CD as your first priority.
3. Save and exit.
4. The PC restarts and follow the instructions on the screen. (Press any key to boot from the CD).
5.After system has finished, such will happen <Enter-To Continue R-Repair ESC-Cancel>.
6. Choose R to repair.
7. A black screen pops up, just read and type 1 and wait for the next step (password).
8. Put in your Admin Password or press "Enter".
9. Then type CHKDSK and press "Enter".
10. the system will repair the errors within the HDD and windows and later restart the PC. Good luck
2helpful
2answers
I get a blue screen error message ''c000021a unknown hard error'' after running CHKDSK as a result of receiving an initial blue screen error message ''The Type of file system is NTFS. The volume is...
Hi, Boot into Safe Mode by pressing F8 at bootup and choose
'Safe mode with command prompt'
At the command prompt type
C:\Windows\system32\restore\rstrui.exe
Hopefully System Restore will open so choose a Restore Point a few days ago.
Please rate my response!! Thanks, SF
1helpful
I have a dell desktop running Wondows XP 2000.
There are lots of possibilities like faulty ram or may be virus in the system or may be the windows file is corrupt try to repair the windows installation. or take the backup of system and the format the system
Stop: c000021a {fatal system error}
start in safe mode with command propmpt and type chkdsk /r/f and let the system get scan.
How do you solve: c000021a fatal system error the windows logon process system process terminated unexpectedly with a status 0xc0000005 (0x0000000 0x00000000) on a dell dimension 5000 using xp home...
most likely the ram memory is bad, or the windows file system is corrupted. test the ram with memtest86 (http://www.memtest86.com/) and/or replace it. if the ram is good, all you can do is backup the files and reinstall windows. to reinstall windows, use your disks, or press one of the following keys when the computer boots up:
sony = F10
hp = F11
1helpful
2answers
My pc`s screen is blue and it sais stop:c000021a ,is there? anything I can do to fix it
hello there
here is some information that should be able to explain this error and how to fix it ok?
best regards michael
  1. How to troubleshoot a "STOP 0xC000021A" error ... presents advanced troubleshooting steps for the STOP 0xC000021A error. ... STOP: c000021a {Fatal ... Note Most STOP 0xC000021A errors occur because Winlogon. ...support.microsoft.com/kb/156669
  2. "STOP: c000021a (Fatal System Error)" Error! RE: "STOP: c000021a (Fatal System Error)" Error! Ya, thats what I thought I might have to do ... RE: "STOP: c000021a (Fatal System Error)" Error! just input the ...www.msghelp.net/showthread.php?tid=66202 - 52k - Cached
  3. How I fixed my Windows XP Stop c000021a {Fatal System Error} with ... How I fixed my Windows XP Stop c000021a {Fatal System Error} with Knoppix Linux. 2008 March 14 ... Message: Stop c000021a {Fatal System Error} The Session ...healyourchurchwebsite.com/2008/03/14/how-i-fixed-my-stop-c000021a-f... - 53k - Cached
1helpful
STOP: c000021a {Fatal System Error} .. 0xc0000005
The first thing you should do is back up the HDD, Remove the HDD from your Laptop, you find the lid that opens the HDD access slot under the laptop or ask someone who knows how. if available there are aftermarket 2.5 HD enclosures that lets you install the 2.5 in.hdd of your laptop via a usb. you can plug the usb to a desktop PC and backup your files. then reformat your hdd. reinstall the hdd to your laptop. replace your memory ram which causes the blue screen with a new ram, reinstall the OS.
Grand Canyon Tech
Grand Canyon Tech
