Do you hear the fan start up? or does the projector lamp come on (you start to see an image)?
If yes to either:
When the temperature inside the projector reaches a
certain level, the projector will be automatically shut down
to protect the inside of the projector. The POWER indicator
is blinking while the projector is being cooled down. When
the projector has cooled down sufficiently (to its normal
operating temperature), it can be turned on again by
pressing the POWER ON-OFF button.
Note:
After the temperature inside the projector returns to normal, the
WARNING indicator still continues to blink. When the projector is
turned on again, the WARNING indicator stops blinking.
Then check the matters below:
– Did you provide appropriate space for the projector to be
ventilated? Check the installing condition to see if
ventilation slots are not blocked.
– Is the projector not installed near the ventilation duct of
air-conditioning equipment which may be hot? Install the
projector away from the ventilation duct of airconditioning
equipment.
– Are the air filters clean? Clean the air filters periodically. Let me know if you need to know how to do this.
If no to either:
When the projector detects an abnormal condition, it is
automatically shut down to protect the inside and the
WARNING indicator will be red. In this case, disconnect the
AC power cord and reconnect it, and then turn the projector
on once again for check. If the projector cannot be turned
on and the WARNING indicator emits a red light, disconnect
the AC power cord and contact the service station for check
and repair.
Please let me know if this helped solve the problem. If not, is there anything else you observed - whether or not you believe it's relevant.
After unpacking from a move, I couldn't get it to power up. Changed power cords, tried using the remote to power up, Nothing. Not so much as an LED.
Sharp XR-11XC projector unexspectedly shut down. No power, no indicator lights, nothing. Changed lamp, changed power cord, tried plugging power cord into other electrical outlets in the home. Nothing Nada.
Can somebody through me a clue? Is there an internal fuse?
I was just watching a movie on my XR-11XC Sharp Projector when it powered down without warnings or indicator lights. The bulb still had about 60% life last time I checked. Now I can't get it to come alive. No lights, no noises, nothing. Is there a reset or?????? Help
I experienced the same behavior while using my projector last night. It turned off while I was watching, tried plugging into different outlet, no power indicators, etc. Extremely bummed about this. I figure either there's a fuse or the power supply is blown. Looking for a service manual.
After an unexpected shutdown during a movie, the unit does not power up. I changed the bulb, but it still does not turn on. No indicator lights are lit, no fans running. It is completly dead.
right on - thanks much - this fixed the problem........
