Anyone help with identifying this fault. Canon 350D powered off, even with the battery door open, yet as soon as a battery is inserted the mirror starts flicking up and down. The flicking wont stop until the battery is out of the camera or discharged. Closing the battery door will change nothing but occasionally the LCD will display ERR99. Otherwise no other signs of life, no movement from shutter. No lens attached. Many thanks for your interest.
SOURCE: Error 5 on Canon eos 350D
Well first of all you can try a full reset, Pull both batteries out -the normal one, and the date/time one. If your camera is older (>2 yrs), it may be time to replace that battery..... anyway Put a new one in, and then put in the freshly-charged main battery, that might clear the error. If further you have the same problem then something is causing the flash to stick. Press the button and pull gently on the flash. Post comments for more help or information needed.....
Good Luck!!
Thanks for using FixYa!!
