Black ink streaking, skipping
SOURCE: The black ink on my HP 450c prints with white
Send an email to me at [email protected] and I can send you a checklist of all the things to look at as it is too large to include here.
SOURCE: HP L7700 officejet printer leaves streaks on black
Print in grayscale (black area streaking only)
If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE:
This step does not apply to color printouts.
SOURCE: Black ink streaks on back of photo
please follow the onscreen instructuions from the below mentioned URL and hopefully this should fix the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00829344&cc=us&lc=en&dlc=en&product=3301296
if the issue is not solve follow the below step
print a test page from printer still the issue is not solve thy to make a copy then also the issue is not solve follow the below step
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00837561&cc=us&lc=en&dlc=en&product=3301296
if still the issue is not solve then call the hp toll free number
1800-474-6836 they will replace the printer if the warranty period is there.
hope your issue gets resolved
thanks
regards
hamid
SOURCE: Streaking effect during printing Officejet 7130
As you have replaced the both cartridges and still the issue persists, then this is a hardware issue with the unit. Please repair your printer.
:) Dr Tony
SOURCE: black ink streak on left
Run a half test.
Put paper in the manual feed tray(tray 1).
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
