Question about Ryobi Blower Vac 205mph Leaf Blower Or Vacuum Gas Powered Gasoline Zr08510
Ryobi blower stalls
When you press the throtle it stalls
    New Friend:
Not sure if your model has two throttles or one. It should have a trigger and a thumb lever. Be sure the thumb lever is closed. if that is not the problem your mixer might be to rich. it says 50:1, but use 40:1 and see if that helps
Posted on Jul 03, 2012
6ya staff
SOURCE:
97 pathfinder shutoff when u step on the brakes hard, now when I start it
The first thing is to make sure the truck is running good. A misfiring truck would cause a low idle and stall.
If the truck runs good then look at the throtle body, a dirty throtle plate will cause a stall and lower than normal idle. If its dirty use a tooth brush and some throtle body cleaner to clean plate. make sure to open the throtle plate by stepping on gas pedal or by hand where the gas pedal cable connects to throle body.
I would check the throtle plate first, also make sure air filter is good.
If all is clean, (plate) and engine is running smooth and no check engine light is on then i would check the idle air control valve.
GOOD DAY.
Mar 03, 2012 | Car Audio & Video
Chainsaw dies out when gas is pressed to full throtle
Carb needs teardown and cleaning. May be a stuck float or clogged jet.
Spraycleaner just wont cut it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2010 | Poulan Pro Chain Saw 46cc 20"
Car stalled. restarted and did a
try blowing out all the fule lines and changing the fule filters the lines may be blocked up also check the fule tank vent if this is blocked the pump cant **** fule from it
Mar 07, 2010 | 2000 Dodge Intrepid
Idling good start good but stalls if pressing throtle
there is a piece of debris floating around in the sediment bowl of your carburetor, its lodged in the high speed jet causing it to stumble and backfire......it will most likely need a carb rebuild average repair cost on this machine is around 150 dollars at a reputable polaris dealer
Nov 19, 2009 | Polaris ATV
Pontiac G6 2005 - starts then stalls immediately
Chage the throtle possition senser.
Jul 03, 2009 | 2005 Pontiac G6
Have a 1985 mazda rx7 will not idle .. cold start ok when choke is on once warm stalls and will not idle
There is a throtle adjuster right behind the carb. You can adjust it with a screw driver. If you are not sure where it is, just have someone press to gas pedal and you will see it move. RPM's at idle should be around 1,000 when it is idle once it has warmed up. Once that car warms up the choke moves back in and the car is probably stalling because it is not running enough RPM's.
Jul 01, 2009 | 1985 Mazda RX-7
My 88 s10 cranks but unless i pump gas pedle it shuts off. changed fuel filter and throtle body sensor still wont idle .press gas pedle it stalls out must pump pedle to keep it running
what engine does it have? 2.8 ? if so replce pick up coil in distributor /4.3 and 2.5 will do this also it affects pulse to injectors and on time firing
Jun 30, 2009 | 1988 Chevrolet S-10
Bike starts fine and idles, when i twist the throtle it stalls
does this happen all the time or just sometimes?if it happens all the time you need t change your spark plug sometimes you probally have water in the gas drain the carb bowl the little flat head brass screw on the bottom of the bowl make sure your gas is on to flush it out buy some stabil ethonal treatment and run it every tank fuel good luck
Jun 25, 2009 | 2001 kawasaki KLR 650
Ryobi Blower Vac 205mph Leaf Blower Or Vacuum Gas Powered Gasoline Zr08510 Logo
901 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Dennis Tokarzewski
Level 1 Expert
Wayne McNeil
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
