Bosch dishwasher model # SHU3035UC/U12
Timer is sticking between the wash and rinse cycles and must be
moved manually to complete the cycle.
Is there a diagram available that would assist me with replacement?
What is the cost of the timer and is it available online?
Thank you.
Hello. Is the water getting hot? Usually the timer won't advance because it isn't getting a signal from the thermostat that is on the bottom of the tub, so it thinks that the water isn't hot enough to go through the rest of the cycle. That is if the water is hot. If it isn't hot then you may need a new heater. You may or may not need a new timer. Try the thermostat first because that is usually the thing that goes out and it is less expensive than the timer. You can order it from www.coastparts.com or www.marcone.com .
Let me know if you need anymore help.
i have the same problem with my hotpoint the dial stick but thermostat is fine
SHU3035uc/u12
