Hi - Am trying to find the product manual for a Baumatic built in oven (B600). In particular finding out how to change the volume setting for the timer.
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
The model number is BA 'oh' and not BA 'zero'. Contact the Customer Care department direct. You are right, no manual online but there is this one, the BAO6009
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again [email protected] hope this helps
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories.
I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe.
In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link:
http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B
Hope that helps! ;)
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
