Turn on the laptop there's black screen and nothing I have tried widows os recovery disc , nothing....it's useless because there is nothing on the screen to begin with how am I supposed to do anything at all?
SOURCE: ibm think pad 2635 cant do anything. please help
its the bios battrie is dead. simply replace the batt and it will work or just pull the bat set the time and it will restart then you will jsut have to do that every time you start up
SOURCE: when i switch on my laptop a black screen just
hi,
this seems to be a hdd issue so get it serviced.
SOURCE: Black screen NTDLR Press any key to restart
It sound like your hard drive has crashed. There is no easy solution to your problem. Here are a couple solutions. You need to run a "chkdsk". It will scan and fix file problems on your HD. To do this you can either download a boot disk like "Ultimate boot disk" or you can take the HD out of your laptop and attach it to another computer. Neither of these are easy, for the boot disk you need to have software that can burn a "iso image" to a cd and to attach the HD to another computer you have to have the proper adapter. I would be happy to walk you through either one of these, just let me know. The easist thing to do would be to contact Acer and get recovery cds then go buy a new hard drive. I would take the old one to the store, to be sure I got the right replacement HD.
SOURCE: gets stuck on the "asus" screen when i trun my laptop on.
Could be that the hard drive is not making a good connection. Turn the laptop upside down. Find the "latch" where the hard drive is "housed" and remove the drive... Then carefully and firmly replace it and make sure it makes good contact. Then try again to boot the laptop. If it still does not start up TAKE IT BACK to where you bought it from and let them sort it out 'cause it is supposed to be under warranty for at least 1 year
SOURCE: Help! My Dell Inspirion 1525 laptop crashed, black
0F00 errors are hard disk drive errors. You will need to replace the hard drive. If under warranty, call Dell Tech support. If not, then you can buy a new drive from places like Newegg.com
