Heating & Cooling Logo
jeff bouwmeester Posted on Jul 03, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What's your problem? changed batteries now controller wont work
Marvin
Level 3:
Top Expert:
  • Fujitsu Master 85,242 Answers
  • Posted on Jul 03, 2012
Marvin
Fujitsu Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024325
Points
266281
Are you sure you have the batteries in correctly? This is a common mistake so please take a minute and verify it.
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Ceiling fan remote control doesn't work
Sounds like you have an add-on remote. Try changing the frequency in the receiver & transmitter. If that doesn't work you probably need a new receiver.
Changed batteries, now won't control power
It is possible you are using the wrong type of battery. A lot of electronics require you to use either Lithium-Ion or less powerful ones. I had this happen once by putting in batteries that were the right size, but were meant for more powerful devices. If you have a cheap set of the right size batteries laying around that are a different type, try those.
My fuse box is blown
you need to check battery supply most important. if the battery low voltage, cause no start. if the battery ok & strong energy. maybe the drive away protection control if this is the problem you need to bring to BMW dealer to replace control & ENCODE the control unit using SSS.
Rca remote won't change different inputs
1) test the batteries for dead
2) clean the contacts batteries
3)tight the springs contacts batteries with long pliers for better contacts
4) open the remote control clean the KEYPADS for dirty, oxide, corrosion and fix itl
5) try it
6) if doesnot work,you must go to the repair shop TV for fix it.
God bless you
92 wrangler wont start
Jiggle the wire connectors going in to the computer under the hood -- first check battery cables/terminal connections at battery -- beleive it or not, connection could SEEM good because you get crank & lights, but if it's faulty, loose, engine won't start - computer requires good solid voltage flow.. next check a fusible link very close to the battery off of the positive cable. check fusible link carefully. this could cause your problem for sure.
I have Aiwa TV MODEL No. TV-A219 The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control. Its
Hello
Check your remote control hanset for proper functioning. Get into this link to know more about the faults and repair to remote contorls.
http://www.fixya.com/support/r10192276-cleaning_remote_control_handsets
If remote control functions proeerly, the front panesl switches to be suspected. If any one mong the microswitches inside got strucked, all functions will be distrubed. it will be best to follow any more after replacing these microswitches. These switches can be located just behind the control panel of the tv, soldered diretly to a printed circuit board. You have to replace all of the at the same time. Just undolder one amoung them as as sample, when you go to buy for a new one.
If this also does not help you, repalce its memory IC. This IC can be located very near to the main system control IC, will have 8 solder terminals. A very small IC and wont cost more. Eventhough it is very small, function of it when the set works is great. Replace it. When you buy this IC, make a keen look on it number. It is very important when replacing this IC. All these components stated above, can be bought from most of the electronic spare part selling shops st your town. OK.
I cant use my controler because the green part keeps bliking and wont turn on so i cant play my xbox 360
I had this exact same issue the other day. Changing the batteries did not work for me, but don't cross that off of the list quite yet. This worked for me:
1.) Pop the battery pack off of the controller. This is the only way you're going to be able to turn it off. Wait about 5 seconds and put the battery pack back into the controller.
2.) Turn on your X-Box with the power button ON THE CONSOLE. It should turn ON. If it doesn't, unplug the X-Box for 30 seconds, plug it back in, and try again.
3.) When your X-Box turns on, go ahead and hit the controller's power button. Things should function normally from this point forward.
Please let me know if this works for you!
My TV remote control has stopped working. I've tried changing the batteries but it still doesn't work. Any tips or do I have to get a new one?
Check for rusted battery contacts due to leaked batteries. Clean them with polish paper or blade. Due to leaked batteries it is quite likely that the wires connecting remote control pcb & battery contacts are cut off.
sonsunny
FAN WONT WORK WITH REMOTE
Check the battery of the remote control, if it's week, change the battery. If still not working, bring it to a qualified electronic technician if they could still fix the remote control, if can't be fix buy a new remote control.
Top Fujitsu Heating & Cooling Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
