Kocaso M730W 1.2GHz 4GB 7 Capacitive Touchscreen Tablet Android 2.3 Logo
jalen caballero Posted on Jul 02, 2012
Wifi doesn't connet
My wifi worked fine but one day the wifi stopped working the only way my tablets wifi stats working is when i restart my router and i have rastarted my tablet but it didn't do anything please help!!!!!!!!!!
ejs31
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 02, 2012
ejs31
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
249
Points
Turn it off then back on
My tablet was working fine when I brought it from Amazon now it won't coonect to my wifi it says establish reliable connection to the server, I tried other WiFi connections same message
Go to your setup setting and check your wifi setup might have change because it not storing the setting might have a problem with the tablet would replace if under warranty
How do I get farmville 2 to stop restarting every few key strokes on my kindle fire tablet. Playing WiFi off is ok, I need to be WiFi on.
Well, Looks like we have the same problem.
The Web Portal that supports the games are having issues with their servers... it's not your server... It will work again and it will gives you problems again... best is to delete the game and re-install, most times works. I do that sometimes good luck
Certain apps that need wifi don't work even though I have perfect wifi signal. I've already restarted my iPad mini, charged it, and turned on and of the wifi a few times, but that didn't help
Possibly one app is locking up networking... My gf had this problem after ios update to 8.0. It turned out facebook app became messed up. I uninstalked facebook and everything was great. Reinstalled facebook and it worked fine after that...In fact her whole ipad got faster... IOS updates are becoming painful...
1helpful
It's a blank page. Why?
Reinstall the app, I assume wifi is working?
I just got my kurio 7s last week and now the wifi wont work. the wifi turns on and its picking up my router even says it has perfect signal i hit connect then it keeps going through this 10 min ****...
If you can click on your wifi and pick "forget" do that and then restart the tablet and try again. If that doesn't work try going to settings and resetting it to factory then it will be like a new one, if you can do it without wifi some tablets wont let you past the wifi screen until you sign on.
2answers
I have the Archos 101 internet tablet but have been having trouble connecting to the wifi recently, I try to connect to a secure connection (I have the password and it is correct as I did connect a few...
Hi there. I noticed that sometimes Android devices seem to have trouble connecting to certain access points or.they seem to stop connecting alltoghether to certain routers. Sometimes this method can help: Select the network you are trying to connect to and select "forget this network". Reboot the tablet and try to reconnect again. Sometimes this doesn't work on the first try. If that doesn't work I have heard of other fixes but they require "rooting" the tablet which could be potentiall dangerous. Another thing you can try if that doesn't work is change the security to a different encryption type. Your password will either be WEP or WPA. Whatever it is try to change it to the other. I cannot give you detailed instructions on this because I don't know your router model or its current settings. Hopefully this helps and leave a comment if you have further questions. Good luck!
Top Kocaso Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
