I did not get a manual with the freezer--not sure about the plug on the bottom (inside) or if it needs a drip tray underneath?
SOURCE: Need to empty drip pan. How do you remove the
The standard procedure is to remove the plastic grill at the bottom of the front of the freezer and then slide the pan out for cleaning and emptying. Might as well vacuum dust out while your at it. Helps the compressor operate at a cooler temperature.
Please rate this answer for me. Thank you.
