Printer won't print. I get an error message that says there is no paper, but there is paper.
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction
The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused.
NOTE:
The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking."
Blinking lights
Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first.
Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution.
Issue: Power light is blinking
Solution
Close the cover.
Cause
Printer cover is open.
Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper.
Solution
Cause
The printer has difficulty picking up label media.
Solution
Follow each of these steps until the problem is resolved:
Cause
There is a paper jam.
Solution
Cause
There is a problem with a print cartridge.
Solution
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
SOURCE: hp 3520 deskjet is showing out of paper when it is NOT
Insert Printer Driver Disk And Uninstall The Printer Driver completely.Dont Remove It From Control Panel. You May Use Uninstaller Software.Here's The Link (ONLY FOR WINDOWS VISTA AND WINDOWS XP)
http://wugnet.com/shareware/spow.asp?ID=638
Install thisand remove printer driver. Delete temp and prefetch files as well. Disconnect Ur printer from the computer and turn it off and then disconnect the power cable. Press n hold the POWER BUTTON on the printer for 30 seconds so that static is released. Disconnect all the cables from the back of the computer and then Press n hold the POWER BUTTON on the Computer for 30 seconds. Restart Your system and hook up the printer and visit the following website
DOWNLOAD AND INSTALL the latest driver software and firmware.
WINDOWS XP
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=305968
WINDOWS VISTA
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808478&lc=en&dlc=en&cc=us&lang=en&product=305968
ANY OTHER OPERATING SYSTEM
FOR ANY OTHER OPERATING SYSTEM CHOOSE OPERATING SYSTEM AND DOWNLOAD AND INSTALL the latest driver software and firmware.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=305968&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
Restart Your System.
Issue Would Be Resolved..
SOURCE: Unexpected Paper Size error while printing a3 size
Although you have selected the paper size A3 your printer HP Deskjet show unexpected paper size.....
1. clean the carriage area ...........
2. change the carriage sensor....... If not solved
3. you need to replace carriage unit.
Thanks
SOURCE: Hello, I have an hp deskjet f300 printing error
I found this site to be most helpful and it went beyond the manual.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=1128298
hope this helps you
