Bosch Nexxt Premium Washing Machine Drainage Blocked. I have cleaned out the impeller and it is spinning freely when on pump cycle now. However it is still not fully pumping, It attempts to drain for the full cycle and then informs me that the drainage is blocked. What would be the next thing to check? The washer is draining partially but not fully.
You need to check the drain pump externally to see if the pumping is good Also remove the drain hose clamps and remove the drain hose flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining. Replacing the pump on a Bosch machine, please check this link for tips:
SOURCE: NEXXT Premium will not spin or drain
There should be a filter located at the bottom right front of washer behind drop down flap or plastic cover.
Unscrew anti-clockwise to remove and clean.
Testimonial: "Thanks. Great advice. We found a sock clogging the drain."
