SOURCE: Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
SOURCE: hoshizaki condensor fan motor is not working
Too long to explain sequence here. but in the harvest mode the fan will not be running. go to hoshizaki.com you will find every thing you need very helpful site . and a clean machine is a happy machine. hope that helps Tom
SOURCE: 3 yr. old Hoshizaki km630 mah, Had a hard
There should be a reset button on your control board inside the electrical compartment.
Turn the system on to ice mode and depress the reset button. This should clear out any and all faults stored in the board and the machine should at least attempt to come back to life.
Look on the outside of the electrical compartment cover. There should be an explanation of what your error code means. I can't remember it off the top of my head. But the list there will tell you what 1 beep every 305 seconds means and the procedures to take from there.
Testimonial: "yes,the reset button is there and reset didn't fix but also had all the directions on the panel to explain things.Ended up replacing circuit board."
SOURCE: Hoshizaki KM-900MAH Ice Maker it sounds like it is
You need to look a litli further to give us more of a clue to the fault. are the evaporator plates getting cold? Is there water flowing over the plates?
SOURCE: hoshizaki KML-450MAH ice maker wont start after clean up
If you did a cleaning cycle and used the bypass valve to clean between the evap plates, look for the micro switch on the bypass valve to be bad. It is a small switch attached to the by pass and keeps the compressor off during the cleaning process. I'd start there.
what is your question about the main control switch?
