Need schmatic and op instructions for Epiphonic V preamp (Mine is not working)
SOURCE: Epiphone volume and tone controls
The controls should be setup in pairs (as long as the electronics haven't been modified. The two closest to the pickups are the volumes and the other two are the tone controls. The top knob set should be your neck pickup and the bottom set is for the bridge.
Schematics and wiring diagram for the typical les paul (sheraton) controls:
http://www.guitarelectronics.com/product/WDUHH3T2202
SOURCE: Need to replace the amp jack nut, Epiphone Dot
Just take the guitar with you to a local guitar music store, where you'll have to go anyhow to get the part, and the store will be happy to repair it for
the price of the part.
SOURCE: Output jack on a Epiphone Les Paul came out and I ned a schematic
google your problem. i have found scematics on everything. i'm currenly changing out the pickups on my les paul, and saw the diagram on your soldering setup. i've done these myself. i was a little worried at first, but it turned out to be pretty easy. good luck, scott
SOURCE: HELP!
This is exactly how any 2 pickup, 2 volume, 2 tone, three way switch guitar would be wired from the factory. Best of luck!
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_2v_2t_3w
