Power went out yesterday-fan works by itself-compressor makes humming noise but doesn,t come on to blow cold air-unable to locate reset-removed cover and see blinking green light
SOURCE: No heat, just cold air blowing
the problem you are having is usualy related to. #1 a high limit condition.(check the filter,then cycle the power off then on). Does the furnace have a diagnostic indicator?
SOURCE: heat pump not cooling after wiring damage repaired.
Do you have the model number? This would help find the code
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have a packaged unit with heat and air. Under
Push the reset, the worst that can happen is it will fault on a safety circuit again.
SOURCE: my unit is starting but
Is the compressor also not running? Check the breaker and see if there is power to the unit. If it is just the fan not running check fan capacitor and go from there
