Heating & Cooling Logo
A
Anonymous Posted on Jan 12, 2018
Fan not spinning on Amana RCB30B2A unit. Compressor is running though
The fan is not spinning on my Amana RCB30B2A A/C unit. Compressor is running though. I was able to get the fan running by giving it a small push through the guard with a paint stick. It seems to rotate freely and has continued to do so since I gave it the push. Is the motor going bad or something else?
Andy
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 572 Answers
  • Posted on Jan 12, 2018
Andy
Master
Level 3:
Loyalty:
Answers
572
Questions
0
Helped
209432
Points
1498
Bad capicator. Replaced it and should be fine
Michael Youngman
Level 2:
Sergeant:
  • Expert 296 Answers
Michael Youngman
Expert
Level 2:
Sergeant:
Answers
296
Questions
0
Helped
180297
Points
743
It's the run capacitor for your fan. You'll need to pull it out and replace it. Look on Youtube about how to replace a condensing fan run capacitor. Make sure you get the same voltage and microfarad rated capacitor. Make sure you also disconnect the power to the unit. You can get the part at any HVAC parts house or Grainger. Should cost around $15
5 Related Answers
Anonymous
  • 83 Answers
  • Posted on May 21, 2009
SOURCE: Outside compressor fan won't spin without a nudge
either you can lubricate it by spraying wd40 on the bushings. Although usually fan motors are permanently lubricated there are still dust particles that get through and cause it not to spin.
Anonymous
  • 70 Answers
  • Posted on Jun 28, 2009
SOURCE: Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Anonymous
  • 82 Answers
  • Posted on Jun 29, 2009
SOURCE: a/c is drawing 20 amps and keeps tripping breaker after running
If the fan is running and the compressor is getting hot and tripping off you may have a failed capacitor.
Lollo Pop
  • 134 Answers
  • Posted on Jul 16, 2009
SOURCE: Compressor hums but fan not turning. Pushed fan to
cap most likley
Anonymous
  • 534 Answers
  • Posted on Aug 04, 2009
SOURCE: Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Testimonial: "Yes, it's dual run capacitor problem. I used a stick to spin the fan blades and it starts to slowly spin and up to normal speed, so motor is good."
I have an Amana heater/airconditioner (Prestige I think) that is not cooling. The outside compressor fan was not spinning, so i I changed the capacitor on the unit. It now spins, yet vent air not cold
If that fan stopped your compressor overheated, shut off on thermal overload. Carefully cool compressor with water hose and restart. If the big copper is cold ,small copper warm, compressor is running. Check capacitor on compressor
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
1helpful
Amana refrigerator SQD23VW
If the freezer is not freezing. I am guessing that the refrigerator is not cold also. Here is link to an Amana Refrigerator Not Freezing. You will need to narrow down parts that are working and are not working. I would first pull the refrigerator out to make sure that the compressor and the condenser fan are running(the condencer fan motor runs to cool the compressor down). This is a link to a GE refrigerator condenser fan motor problem. The compressor and condenser fan motor are in the same place. This can give an idea at least where it is at. Make sure that the evaporator fan motor in the freezer is running also. Make sure that the rear freezer wall is not iced over. This can be a defrost problem. See what a defrost problem is HERE. If your unit is sitting there with the lights on but you hear no noise from any fan motor or your compressor. Your unit may be in a defrost mode. Locate your defrost timer. It looks as tho it is either located in the front behind the kick plate or in the back by the compressor. Here is a link to your units diagrams http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VW-P1315302WW/1268/0165000/P9060266/00011?componentDescription=&brandDescription=&searchTerm= or http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Refrigerator-Parts/Model-SQD23VWP1315302WW/1268/0165000?searchedModel=sqd23vw&blt=11 . Hope this helps a little. This is my Appliance repair Contact. You can get a hold of me at http://www.apcoapplianceandair.com/contact.php anytime.
Fan not turning on my Amana RCB30B2A a/c unit
Try checking the capacitor inside the electrical panel on the unit. Usually the capacitor will be swollen or even exploded if it is bad. To properly check it, you will need a meter that measures MFD's (microfarads). It will have an amount printed on the label. I have attached a picture of what they look like new. Hope this helps and good luck!
WARNING! Capacitors store electricity. Also make sure all power is off before performing any work!
1helpful
2answers
Amana Prestige II air conditioner. The fan unit on the top of the ouside unit stopped spinning. I gave the fan a good push and it started spinning (and continues to spin) however the air now blowing into...
You need to replace the fan capacitor. Your compressor is probably in thermal overload you can cure this by turning off the disconnect your ac voltage and taking a cool water hose and running over the top of the compressor for a while. Then turn your disconnect back on and listen and feel of the big copper line to see if it gets cold and also listen to see if the compressor kicks on.
1helpful
I have an amana 90 home air conditioner w/ a amana prestige compressor. compessor runs but cooling fan not turning ,fan is not locked up and unit has power .of course w/fan not turning home is not...
Could be a couple of reasons for this:
1. Condensor fan motor bad.
2. Condensor fan motor loss of power.
3. Condensor fan motor capictor bad.
Unit has control for fan for low ambient operation and unit is low on freon telling fan its cold out side and dont run.
Hope this helps. wally
My Amana Side-by_Side SXD26VL is not cooling. The
clean cond coil at back of unit.
check amp draw on the compressor wires.
1helpful
Dave
I have a Amana air command 80 sse central air unit. The unit is comprised of a big fan unit outside, and a unit in my garage. The big fan stays on even though I turn the thermostat off. Do you know what...
This sounds like your condenser contactor, contacts are stuck. They weld together if an ant or other debree get between the contacts. Turn off the electric breaker to the outdoor unit as if the outdoor unit runs without the indoor unit running you may damage your outdoor unit compressor.
I would suggest you call a service company. The part should run retail @ 30 to 40 dollars then the service call charge. This repair should take less than 1/2 hour.
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
