Water stop
SOURCE: Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve
85297-AA. My toilet kept running, the fill valve black cylinder
wouldn't pop up and when I added blue food coloring to the tank, the
blue color seeped through to the toilet bowl. First I replaced the
flapper and that allowed the fill valve piece on the cylinder to pop up
correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had
filled and no water was going into the overflow tube. I called the tech
support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) .
Here's what solved the problem: Turn off the water to the toilet.Take
off the white cap of the fill valve by pushing it down and turning it
counterclockwise as you would open up a childproof pill container. Then
unhook the metal hook. Hold a cup upside down (I used a strong plastic
cup) over the part of the fill valve that is left in the tank and turn
on the water. (You need the cup because otherwise the water will squirt
up to the ceiling.) The water will flush out the fill valve. Replace
the cap and the hook and flush.
SOURCE: my duravit toilet keeps running
I too have had this problem. No matter how i change the settings ..sooner or later the toilet starts to flow continually getting worse and worse. I have had plummers and friends etc see if they can make it stop and it is no better. I am very disapointed with it and will never ever buy Duravit again. I tried contacting them for help and got nowhere. Bad design. Waste of money.. I should have stuck with the old ball-**** system at B&Q.
SOURCE: The toilet is only 2 months' old. The water keeps
Remove the top of the water tank.
check to be sure that the flush cover (about in the center of the tank) can close all the way. It seats into a 2 inch hole - and must seat all the way around. If it fails to seat, then the fill valve (on the left side of the tank) will continously let water into the tank.
As a starter experiment, you may try just turning whe water off at the wall shut off. Then inspect the tank to confirm that it is losing water.
If confirmed, then the above solution is correct.
If it is not losing water, then the fill valve is faulty and will need to be replaced (it is allowing water to over flow into the "OverFlow" tube.....
I recommend that you keep the water turned off at the wall until the toilet is needed - and the problem is repaired.
SOURCE: Toto Neorest 550 toilet water keeps running
flapper is leaking or worn letting water run thru
