Sony Handycam DCR-TRV250 Digital Camcorder Logo
Posted on Dec 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camcorder won't play recorded tape
I have the Sony digital handycam steady shot DCR-TRV250 NTSC digital 8 camcorder and when I try to play back recorded video it either won't play or if it does the tracking is off and it pauses and then cuts out. Any suggestions?
  • hamiyyet Dec 20, 2008
    There is a blinking yellow symbol with a line and a triangle on top of it every time i try to open it
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on Dec 07, 2008
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86313
Points
1069
Clean the head and try again
How to play tapes not recorded by Sony Handycam DCR-TRV130 Digital-8 Digital Camcorder
It is my understanding that the camera won't playback those formats, timecode or not. There are VCR type units for the HI8 and other formats. They should be cheap on eBay now...
How can i use camera to take ntsc movie
The DCR-TRV27E only records in PAL format. You can use it to play back a tape recorded in NTSC but you cannot record one.
Sorry if that wasn't the answer you wanted to see, but that's the way this camcorder works.
3helpful
My sony dcr-trv250 ntsc does not play videos that were recorded on my old samsung scx904 or alittle older sony that my father in law had let us borrow before we got ours...why? and is there some way to...
Your DCR-TRV250 uses a Digital 8 system to record and playback information on its cassette whereas the older Analog 8mm machines used the analog system. Unfortunately the two are incompatible.
1helpful
I have a sony digitalhandycam(digital 8)and cant seem to transfer to my laptop
I have a digi8 DCR TRV140E - The USB does not recognise, windows does not recognise it and the only method that works to edit from the tapes recorded to pc is fire cable - try that folks at least it will hold you back from smashing the camera!!
On display is c31;23
Bill, its not the problem with the Camcorder. It the problem with the Recording Media (Digital 8 tape). Try some other tape... It will solve your problem.
2helpful
The no tape and eject symbols are flashing at the same time.
Those signs means Record tab on tape is ON, eject tape and check record tab and make sure to set it on Record position.
Viewing SONY 8mm Tapes -- Please help
The older tapes were shot on a 8mm camcorder and the camcorder you have wil not play them becasue it doesn't have backwards compatability with the older format. The tapes you recorded are on a digital 8 camcorderr and it is different encoding than the one you recorded the other 60 tapes with. You will need to find either a dcr-trv 350 trv 530 trv 730 ect as these have the ability to play all the tapes.
Or find an older 8mm camcorder to play your tapes with.
Hope this helps
Cheers
Al
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
I am having trouble playing a Hi-8 tape in my sony camcorder DCR-trv250
Looks like you have a blank area in the Tape. Try Fast forward and you will get again MM:SS:SS.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
